35cc Stihl
MO
Here is my latest effort. A Stihl 35cc from a FS 108 trimmer. It is set up as a pusher(clockwise rotation) for a 12' span camera platform.
Specs:
Zama C1Q 13mm verturi carb
Stock engine, no change to timing or ports.
CH Syncrospark
18-6 Top Flite Prop
Idle 1800
WOT 8400rpm
I got this engine along with 3 others from a Harris county surplus auction. Its used, but from the appearance it was practically new.
Specs:
CH Syncrospark
18-6 Top Flite Prop
Idle 1800
WOT 8400rpm
MO
Dave
The original carb was a 13mm Zama. However it had 3 needles and I have never figured out how to set it up. The third needle appears to be some sort of accelerator adjustment, but I am far from certain. I've looked at the Zama carb data sheets until I was cross eyed, but never found a model with the third needle. If anyone has ever run into one of these and knows how to set them up, I would apprreciate some information since I have 5 of these.
Will
Will
TN
usually the two needles that are side by side are the hight and low speed adjustments with the high speed being the one farther from the engine. the other needle is not needed and usually just keeps the throttle butterfly from closing entirely. you wont need it b/c you can control this function with your tx after you hook up throttle linkage.
