25cc homelite compression
Old 02-22-2007, 11:14 PM
rivercityflyer
rivercityflyer's Avatar
Default 25cc homelite compression
How do you know how much compression is enough, and how do you check it? I used a screw-in automotive compression gauge and flipped the prop till it would'nt register any higher, i assumed that is correct(?). It was 90 lbs. I'm thinking it should be higher than that. this is a used engine, and thinking about converting it. thanks.
Old 02-23-2007, 12:29 AM
Ralphbf
My Feedback: (27)
Ralphbf's Avatar
Default RE: 25cc homelite compression
I maybe wrong but that is pretty good for a 2 stroke.
Old 02-23-2007, 06:50 AM
w8ye
My Feedback: (16)
w8ye's Avatar
There's nothing wrong with 90 lbs dynamic compression.
Full size airplane internal combustion engines are measured by the leak-down-rate. With the piston at top dead center, a certain air pressure is applied to the cylinder through an orifice and the rate at which the pressure bleeds off is noted on a second gauge.
http://www.littleflyers.com/engcomp.htm
