$25 CDI
TX
I tried one of these on a Zenoah g20. it was a little difficult to start at first but after the engine ran a while, stopped and cooled down, refueled, one flip is all it would take to restart. I used the original pulse switch. It plugged right in. I was testing this on the bench so i dont know of any real world performance. Was hopeing someone else has tried it and could enlighten me.
ORIGINAL: terrymf
My Feedback: (21)
Hobbycity also has RCexell for $28
and change. Like XYZ no sensor [>:]and don't look like they carry it. They call it replacement CDI. Sounds like (or reads like) the XYZ does the job tho. I'm getting some for my plethera of 30cc Homies.
ORIGINAL: captinjohn
I got a CD ignition that looks just like the RCexcell. I will try too hook up my timing light to it when I get a chance. Best Regards Capt.n
Capt,n
#31
TX
Cap'n
Now that you mention the metal cap for the spark plug...I had to dissasemble the xyz plug cap and replace it with the Zenoah cap to get it to attach to the g20. It was a simple operation. Just bend the little tabs open and it comes apart into two pieces.
#35
ORIGINAL: aero nut
I can sell you the Rcxcel ignition for 55 bucks complete with sensor plus S&H give me a PM if interested
Paul
#36
TX
I flew my Ryobi 31cc conversion last weekend with the XYZ ignition that I bought from Hobbycity. It ran flawlessly. I got 5 flights during the day of about 10 minutes apiece on a 6 volt 2100 mah nimh battery pack and was still over 6 volts when I quit for the day. As a matter of fact, It started easier than my Zenoah G20. I would flip the prop with the choke on and the ignition off until I had fuel in the carb. Then one flip with the choke on and the ignition on. Then one or two flips with the choke off and away we go. I have two of these ignitions and plan to use more in the future.
Jim
Jim
#38
I see. I like the one I have. I only have 3 engines on spark. all others are on gas/glow. I think in time the 3 I have will be gas/glow but as long as they work I will run them.
Paul
Paul
#39
ORIGINAL: bat.guy
#40
ORIGINAL: bcchi
This is not a RCEXL ignition. I would guess the timing chip is under all of the black goop and circuit. It is probably a copy of the xl system from the looks of the parts I can see.
Mr. Laing Xu said some one had cloned his ignition Ha. His is a exact copy of my CH system. Looks like the chinese are cloning the Chinese.Very Funny.But I am to old to worry about it.
Send me one and I will tell you if it has a timing control and how it works.I will even send it back. Maybe I could clone it.
BCCHI AMA 2500
BCCHI AMA 2500
#41
I got my XYZ ignitions the other day and installed one on a 25cc gasser from a Feather lite weed eater.
It was easy to get the timing set, starts easily by hand with great throttle response. I'm pretty happy with it.
Mine were on backorder for about 15 days, I bet they are selling like hotcakes, the stock listing on hobby city's website said -14 at one point.
#42
TX
I would like to hear more about you feather lite with the XYZ ignition. I have a 25cc Polaun weed eater engine and had planed to use the same ignition on it. Was curious about your setup. any picture or info would be great. (prop size, rpm, pulse switch mounting, ect)
#43
ORIGINAL: Carpilot
#44
captinjohn, Yes I ordered 2 ignitions and 3 sensors from hobby city. the sensors are replaceable by themselves.
terrymf, As it stands right now I am getting 7450 RPM on an APC 15X8, not bad for an engine with such low compression and 5500 feet above sea level. Now It is taken apart, I sent the jug, piston, and ring to Frank Bowman to have a new ring made for it. hopefully I'll wind up with a better compression ratio.
For the sensor mounting I used a hose clamp around the housing that holds the front bearing and installed a magnet in the prop hub. Also I think CH Ignitions sells a timing kit for this engine too, I ordered one.
I'll report further and take pictures when I get it back together again.
I also stopped into a small engine shop this afternoon and bought 4 more 25cc feather lite weed eaters for 15 bucks each. they all run but need a little carb work, that should keep me out of trouble for a while.
#45
TX
Are those numbers with the stock muffler??
I know my stock muffler weighs a ton and I am going to replace it with a lighter one from wackerengines anyway but was just curiouse about yours...
#46
ORIGINAL: terrymf
No I bought an aluminum muffler for it from wackerengines.com for it. the initial investment of $8.00 for the weed eater seems to have paid off. I'll make another thread for it after I get the ring back and get it running, but I sure am impressed with that cheap XYZ ignition from china.
#48
ORIGINAL: Carpilot
ORIGINAL: terrymf
[*] [*] [/ul]
#49
CA
Hello all,I'm try to use one of these units with a CH prop hub and sensor.I'm not sure of the pin out between the two.Is CH Black=neg,Red=pos,White=signal and is the XYZ Black=neg,Red=pos,unshielded(bare wire)=signal.Any help would would be appreciated.I don't want to smoke these things,I waited almost two months to get this XYZ ignition module.
Thanks in advance Jim.
#50
ORIGINAL: Bladejunkie
The CH pickup tests like a transistor, and the XYZ does not, or at least a different kind of transistor. I don't think the two are compatible.
I measured the CH pickup and found 2 P-N junctions, I only measured 1 on the XYZ sensor, and that's the one I am using now so I know it works.
If I had a schematic of the ignition module I could determine for sure if it would work, or at least find the correct type of sensor. but I have not been able to get a schematic.
Oh yeah, and the magnet on the CH prop hub is the correct polarity to operate the XYZ sensor.
Ira
