$25 CDI
#51
Carpilot...Very good imformation! It is good to find what sensors will work with different CD units. This makes it all more afordible for us all. Please keep up the good work! Capt,n
#52
CA
Thanks Carpilot,I've got the XYZ sensor too,but I like the easy clamp setup on the CH unit.I guess I'll just use XYZ stuff.I tried the unit with the CH hub and got a nice blue spark.I just have to drill and tap my Homie for the sensor and I'm good to go.Thanks again for the info Carpilot.
Jim
Jim
#55
TX
I am wondering if you would even have to use a specific sensor or if any one would work???
This site has some for 2.00 for 4..thats .50 cents each.
[link=http://www.goldmine-elec-products.com/prodinfo.asp?number=G1994&variation=]Electronic Goldmine[/link]
#57
TX
Also..here is a potential source for the magnet needed on the prop hub to operate the sensor
[link=http://www.eamagnetics.com/info_alnico_magnets_prodphotos.asp]magnets[/link]
#58
i've been getting magnets from this place for years...ken
http://www.kjmagnetics.com/proddetail.asp?prod=D11-N52
#60
http://www.prcmodel.com/modeng/name/...e%26catid%3D21
Add $8 for shipping ($44.50) to US this is in Canadian dollars equal to US Dollars is $37.44
http://finance.yahoo.com/currency/co...submit=Convert
AND it works flawless down to 4.4 volts I got 1 hour running time on a 4.8 v 600 Ma Nicad pack!
radio shack 1/8 th magnet $1.99 for 2
it shows us dollars but unless they updated it I got it for the $37 dollars
#61
ORIGINAL: markaboo929
#62
I ordered it on a Sunday on line and recieved it on that Saturday basically 1 week from Canada to North Carolina,They look like they are located near Michigan,Upper state New York area.Not to bad and it works real good.I have it set up on an Echo 1.3 and I am breaking it in on a Evolution 15x6 prop.It has been hitting a little above 8000 rpm ,now thats running on 32:1 oil ratio with lawboy oil.The throttle responce is quick almost like there was no prop on there.Instant.Almost finshed with a gallon of fuel through it.I will go with a 50;1 synthetic ratio after that.
#64
Does anyone know if the CRCC ignition is auto advance??
The unit for the 26cc engine is listed at $35.00, and the one for the 50cc engine is listed at $38.00. I wonder what the difference is between the two??
AV8TOR
EDIT: I checked the 26cc engine description and it says it has auto advance.... Still don't know about the price difference.
AV8TOR
#65
Most common hallsensors are uni-polaire.
A uni-polaire needs only a south form the (neodymium) magnet to switch on / off
A bi-polaire sensor needs a south to switch on and a north to switch off.
http://parts.digikey.co.uk/1/1/87891...37-wl-7-b.html
#66
ORIGINAL: Bigboat
#68
IL
ORIGINAL: Bigboat
I've wondered about that,nicely put.
#69
ORIGINAL: captinjohn
Big Boat...to put it simple, if our pic-up sensors have only one magnet ....are they neodymium? Like-wise if they are bi-polar...you need 2 magnets in hub? I got a feeling you could make the answers a lot more imformitive to us. Capt,n
ORIGINAL: Bigboat
#70
ORIGINAL: Bigboat
If your using a biopolaire, you don't need twoo magnets, but you have to position the magnet the hallsensor can read both sites.......norht and south.
If your using a *horsshoe* magnet, you don't have a problem.
One leg will be south and the other will be norht.
A long (straight) magnet gives your trouble, becourse the norht and south feeld are on top of the magnets in a straight line.
#71
#72
It is for the replacement on the crrc pro 26i in the replacement parts section.I am going to get a nother one for my homey 30cc i have just aquired.And the radio shack magnet works just fine just pass it by on either side and one will make it spark going in the correct roation-counter clock wise-I was trying both sides and it actually will spark with the other side of the magnet in the opisite dirrection!!! hmm.........imagine just having a twin engine plane with counter rotating engines!!! And by the way sometimes my echo 21.2 will start and run in reverse pretty decent too...just wont have full throttle.
#75
TX
This one is 33.59.
Not sure if it is the one refered to earlyer in this thread or not...
http://www.hobbycity.com/hobbycity/s...or_FTL_Engines
