Poulan featherlite exhaust ports
DE
After reading about the bottom of the exhaust port not meeting the top of the piston, I started looking at the two engines I have.
Both clearly have the piston below the bottom of the port. Easy modification. One has the small eye shaped port as pictured in another thread. The second has a much larger opening. Both are pictured. I will probably try to match the smaller exhaust port to the size/shape of the larger one.
