Best Walbro carb for Poulan 25cc ?
A friend of mine is wanting to wakeup his Nieuport 28 a little What model carb would you recommend, I was hoping one of you knew what would bolt on some rpms? A direct bolt up would be best, but rerouting the the pulse hole for the carb isn't out of the question either...Hopefully the guy on ebay carry's what we need.
NJ
RE: Best Walbro carb for Poulan 25cc ?
What poulan 25 is it Four bolt backplatew/bolt on muffler? long shaft blower engine?,if so the 10mm zama that comes with is the best,open up exuast port 16/8 8450,good luck!
Hi Foodstick,
I got my carb off of EBay.
Here's a link to my conversion thread. It has the carb info in the thread.
Mark
http://www.rcuniverse.com/forum/m_7725853/tm.htm
Mark
