28 degree magnet placement?
Old 06-21-2009, 08:11 PM
Jester241
Jester241's Avatar
Default 28 degree magnet placement?
Usually when I mounft a magnet in a hub,I just mark thehubat the center of the hall sensor on the hub at 28 degrees before top dead center and drill my magnet hole on that spot. I've read that hall sensors fire AFTER the magnet passes the sensor. So,should I center the hall sensor on the hub at 28 degrees and then mark my magnet just beside the hall sensor? This would make the spark fire at exactly 28 degree if it fires as the magnet passes the sensor.....meaning the magnet center would be a few degrees MORE then 28 degrees?
I'm using an xyz ignition on a poulan 46.
Old 06-21-2009, 08:21 PM
w8ye
My Feedback: (16)
w8ye's Avatar
Default RE: 28 degree magnet placement?
That's correct but leave yourself some fine adjustment room
Old 06-21-2009, 09:01 PM
av8tor1977
av8tor1977's Avatar
See this post....
http://www.rcuniverse.com/forum/m_8868990/tm.htm
AV8TOR
Old 06-22-2009, 08:12 AM
combatpilot
combatpilot's Avatar
you all might find this hard to belive but i got nothing to say on this subject. Im pretty much done with the forum altogether lol.
Old 06-22-2009, 09:29 AM
captinjohn
Combat, your not going to leave the RCU are you? We will miss you. Hey at least you got some-one to post a good how to video on timing. Stick around.....you, I ,& all of us together make this all worth doing. Best Regards Capt,n
Old 06-22-2009, 09:47 AM
tkg
If you are going to set the timing that way make sure you can adjust SOMETHING about 10 degrees so you can get it exactly right later on.
There are variables in magnets, sensors and air gap that all effect timing.
Old 06-22-2009, 11:03 AM
captinjohn
TKG...right on...that is the KEY to sucess!!! Capt,n.....engine lover!!!!
Old 06-22-2009, 01:05 PM
av8tor1977
av8tor1977's Avatar
If the engine can use a clamp on sensor mount as sold by CH Ignitions for the engines it will fit, the adjustment factor is easy.  If your engine can't use the clamp on style sensor, it is easier to mount the sensor in a fixed position, and use a rotating collar with your magnet in it, mounted to your prop hub.  The collar is fixed once adjusted with a set screw(s).
AV8TOR
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
