Custom Piston Rings
Old 04-21-2011, 07:07 PM
  #151
the Wasp
Default RE: Custom Piston Rings
thank you Frank !!,, on thing,, while Honing should we Lube the Liner, if yes, what should we use ?? (2 stroke oil, motor oil, WD)???
thanks again !!
Jim
Old 04-22-2011, 08:23 AM
  #152
Frank C. Bowman
My Feedback: (13)
Lite oil WD fine, Karosene, etc. Take care, Frank
Old 12-01-2011, 05:17 PM
  #153
captinjohn
Frank....I am going to call you soon. Thanks Capt,n
Old 12-03-2011, 08:46 PM
  #154
captinjohn
I put a Frank Bowman piston ring in a SuperTiger .75 engine and I broke my favorite prop, so I put a 14x8 prop on the .75 and to my surprize it turned it real good. I have the engine on a Funtana 100X. It flew good! Also I am sure that the engine with the Bowman ring is much better on glow fuel! Capt,n PS Frank...some photos!
ID:	1694965   Click image for larger version
ID:	1694966   Click image for larger version
Old 12-04-2011, 05:24 AM
  #155
Frank C. Bowman
My Feedback: (13)
I did have to raise my price on rings I make due to increases in cast iron, tooling, and shipping. The price list is listed below. I also made a mistake in last posting, I heat treat rings to 1,850 degrees F. not 850 degrees F. Thanks to all and have a Merry Christmas. Frank Bowman
Standard Rings up to .29 = $9.00 ea. USD
" " .30 - .65 = $10.00 ea. "
" " .66 - 1.999" bore = $11.00 ea. USD
" " 2.0" - 2.999" bore = $12.00 ea. USD
Dykes Ring up to .29 = $10.00 ea. USD
" " .30 - .65 = $11.00 ea. USD
" " .66 - 1.999" bore = $12.00 ea. USD
" " 2.0" - 2.999" bore = $13.00 ea. USD
Old 12-05-2011, 06:26 AM
  #156
captinjohn
That is still a real good deal when you compare it to the price of about anything RC or even a small bag of food products at a nearby store. Best Regards Capt,n
Old 12-21-2011, 04:12 AM
  #157
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Frank, I'd like to contact you for a ring for a Webra .91 and a SuperTigre 4500 pinned. Could you post you contact info one more time and I'll save it Thanks, Dave
Old 12-21-2011, 04:45 AM
  #158
wattmeter
wattmeter's Avatar
his Contact is on the first post of this forum.
Old 12-21-2011, 04:51 AM
  #159
Frank C. Bowman
My Feedback: (13)
[8D] Hello Dave, I have both rings in stock at $11 ea. Postage $4 First Class or $5.65 Priority. My contact info. email: [email protected] Phone # (505) 327-0696 Merry Christmas
Old 01-05-2012, 10:18 PM
  #160
3D Romeo
My Feedback: (111)
3D Romeo's Avatar
When I got my first DLE-30 engine (side carb) I was told that replacing the stock ring with a Bowman ring would help quicken the break-in period, as well as improve the compression, ease of starting, and engine running temperature. After reading through allot of threads on the side carb version I figured it would be a good idea to replace the stock ring with a Bowman ring. I don't know how the engine would have run with the stock ring, but I know it starts great, and runs great with the Bowman ring, and I couldn't be happier.
Since then I've accumulated a few more DLE engines (DLE-20, (2) DLE-30's, and a DLE-55), and I'm wondering for somebody low on funds (or out of funds in my case lol) would a Bowman ring be necessary to achieve all the things listed above, or do the newer rear carb DLE engines run good out of the box with the stock rings?
I still would like to replace all the stock rings with Bowman rings in the future, as funds become available. But if they aren't necessary for a good starting, good running, engine (out of the box) I'd like to hold off on ordering them for now until I can better afford them.
Any advice on this matter would be greatly appreciated.
Thank you
Mark
Old 01-07-2012, 09:17 AM
  #161
av8tor1977
av8tor1977's Avatar
The Chinese rings tend to be hard and take a good while to break in, but many, many people are using the DLE engines with the stock rings without problems. You could always use the engines you have as they are, and then change them over to Bowman rings at some time in the future.
I too am a big fan of Bowman rings, but they are not absolutely necessary if you can't afford them at this time.
AV8TOR
Old 01-07-2012, 10:03 AM
  #162
3D Romeo
My Feedback: (111)
3D Romeo's Avatar
Thanks for the reply AV8TOR.
I was kind of hoping that was the case. I just wanted to make sure before making a decision.
Mark
Old 01-07-2012, 10:55 AM
  #163
karolh
Just can't seem to be happy if my engine is not running on a Bowman ring
Karol
Old 01-07-2012, 06:36 PM
  #164
captinjohn
Frank...look for some future orders from Florida. I went too a Pylon race and spilled the beans...HA! Capt,n
Old 08-27-2012, 02:39 PM
  #165
bigphil
bigphil's Avatar
Anyone know if Frank is still doing rings? I've emailed him but haven't received a response... [] Need a ring for a Webra 1.20 if anyone knows of any other source.
Old 08-27-2012, 03:50 PM
  #166
Frank C. Bowman
My Feedback: (13)
Hello Phil, I'm still making rings and do have the Webra 1.20 Dykes rings. Email me at [email protected]
Old 08-27-2012, 05:30 PM
  #167
bigphil
bigphil's Avatar
Thanks Frank, email sent!
Old 09-17-2012, 12:48 PM
  #168
captinjohn
My friend has 2 Webra 1.20 engines. From brand new one would hand start. The other engine needed to be started with a electric starter. I replaced the stock ring with a Ring from Frank Bowman...and it hand started first try. It had much more compression and ran great. Best rings on the planet for our RC engines. Capt,n
Old 09-17-2012, 03:15 PM
  #169
bigphil
bigphil's Avatar
I'm already a believer John. I've repaired my friends Webra with new bearings and Frank's ring. Runs awesome!
Hand starts easily, always has...
Old 09-17-2012, 04:08 PM
  #170
karolh
Hey Capt,n,
I just spoke with Frank and he has rings for the M22 plus others, so I'm just waiting for TDA to hopefully give the green light for me to take the plunge.
Karol
Old 09-30-2012, 04:08 PM
  #171
captinjohn
ORIGINAL: karolh
Hey Capt,n,
Karol
That sounds good too me and I am sure Franks rings will be kind to the plating and not wear on it! Capt,n
Old 12-10-2012, 12:25 PM
  #172
captinjohn
I just read in another forum, a guy installed a Frank B. piston ring in a Mintor 22cc engine and gained over a 1000 RPM. Capt,n
Old 12-16-2012, 04:11 PM
  #173
vatechguy3
What about a ring for the new dle 35 rear exhaust?
Tony
Old 12-16-2012, 06:02 PM
  #174
w8ye
My Feedback: (16)
w8ye's Avatar
ORIGINAL: vatechguy3
Tony
Send your piston and cylinder to Frank and he will make you a custom one.
Old 12-17-2012, 06:13 PM
  #175
captinjohn
Just email Frank. Some engines have the same bore size...a metric size and a lot of rings are the same width. He may have one already. He may need to make sure if the ring is pinned & provide for that. Capt,n
