Echo/Shindaiwa four stroke info??
My brother tells me he has scored us an Echo four stroke engine. It has Echo number PB-755 H/T. Some web research has revealed that this blower is also made by Echo FOR Shindaiwa, and has the Shindaiwa number EB633RT. But I can't find much info on it. (My brother lives 250 miles from me and we won't be seeing each other soon.) Anybody know anything about this engine???
AV8TOR
AV8TOR
RE: Echo/Shindaiwa four stroke info??
Try Carr Precision Engines:
Shindaiwa 25cc Engine with kit
Displacement: 25cc
Propeller: 18 X 8
Weight: 4.5 lbs.
Basic Conversion Kit:
(for those who want to do their own conversion work:
motor mount w/ screws, prop hub, washer and bolt.
Price: $75.00
Good luck
Richard/SPACEWORM/ARCAV8R
Displacement: 25cc
Propeller: 18 X 8
Weight: 4.5 lbs.
Price: $75.00
Good luck
Shindaiwa number EB633RT is not a four stroke.
Easy way to tell what it is, Shin's four strokes have blue engine covers, the red covers are on two strokes.
Its too bad, because Shin's C-4 technology is better than Stihl's Four-Mix.
http://www.shindaiwa.com/usa/en/_doc...rs/eb633rt.pdf
http://www.echo-usa.com/product.asp?...ry=POWERBLOWER
http://www.echo-usa.com/documentatio...B-755+T&lang=E
http://www.echo-usa.com/pdf/document..._06_070909.pdf
Well here is where I found it stated that Echo makes this particular model for Shindaiwa: http://cgi.ebay.com/EB633RT-SHINDAIW...QQcmdZViewItem
And here is where I found mention of Echo four stroke engines: http://www.alexander-mills.co.uk/echo.htm
I don't know, my brother says it is a four stroke, and that they told him at the engine shop it was a four stroke that used two stroke fuel mix. But the model number doesn't check out as a four stroke. Guess I won't know till I get my hands on it in person...
Thanks for the answers,
AV8TOR
AV8TOR
My Feedback: (16)
79.7cc or 4.9 ci is the biggest they make
http://www.shindaiwa.com/usa/en/_doc...SellSht_EN.pdf
http://www.lawnmowerpros.com/Shindai...8510-Parts.asp
My Feedback: (16)
There's also a 25 and a 34 http://www.shindaiwa.com/usa/en/_doc...SellSht_EN.pdf
http://www.lawnmowerpros.com/Shindai...2510-Parts.asp
From 2009?? Are you kidding? I can't even remember what I had for dinner last night!! :-(
Seriously, I don't remember what became of that engine. I know I didn't convert it so it was probably beyond repair. I have converted several Stihl 32cc and 36cc four stroke engines however, and they are quite powerful for a four stroke and sound amazing both at idle and at revs. (I run them on a straight stack; no muffler is needed.) I haven't personally done one of the Stihl 65cc four strokes, though I have sold several of them to people to convert. One of them posted a video here in the forum and a quick search should locate it.
AV8TOR
AV8TOR
