Ryobi, convert to IE?
My Feedback: (131)
TN
Ive got a Ryobi 31cc and a Crcc ignition. Need some help, never put a IE on before! Has anyone set this up before? What should I set the initial timing at? What kind of gap do I need between the sensor and the magnet? Thanks for the advice!
About a .020" gap between the sensor and the magnet is fine. Set the timing at 28 degrees before top dead center. Set it so that you actually SEE a spark at 28 degrees, not when the magnet is over the sensor. Some units create the spark as the magnet approaches the sensor, others as it is leaving the sensor.
AV8TOR
AV8TOR
