Magnet installation for Ie how to?
Old 01-22-2010, 10:27 PM
flyrc100
My Feedback: (131)
Default Magnet installation for Ie how to?
Hi, I am going to install a Magnet for an IE in my prop hub, any advice on a good techinque to keep it in place? Press fit, glue it? What kind of glue? Whatever, Thanks!
Old 01-23-2010, 01:49 AM
w8ye
My Feedback: (16)
w8ye's Avatar
Default RE: Magnet installation for Ie how to?
The magnets are very brittle
Old 01-23-2010, 01:55 AM
av8tor1977
av8tor1977's Avatar
I make a hole in my hub a few thousands larger than the magnet, and use JB Weld to glue them in. Never had one come out. If it makes you feel better, you can use a center punch to crimp the magnet in it's hole in a few places.
AV8TOR
Old 01-23-2010, 09:12 AM
Jezmo
Jezmo's Avatar
The one in my converted SuperTigre G51 is glued in with epoxy and then staked as AV8TOR described above. It's been running for over 75 hrs of flight time and never had a problem. The magnet I used is 1/8"OD X 1/8"Long and I drilled the hole with a 1/8" drill bit. The magnet could be pushed into the hole by hand and if bumped on a table would fall back out. I put a small amount of 30 min epoxy into the hole and rubbed some onto the magnet then pushed it into the hole. I staked it in before the epoxy was dry and viola. I used the same procedure on my SuperTigre 90 and it has worked out just as well.
Old 01-23-2010, 10:15 AM
flyrc100
My Feedback: (131)
Thanks for the input gents, sounds like the epoxy method is what I will try first.
Old 01-23-2010, 12:18 PM
WildeOne
Magnet polarity facing the Hall sensor is important. Most want to see a S pole facing the sensor.
Old 01-23-2010, 12:56 PM
Nosedragger
Step 1 drill hole for magnet .010" undesize
Step 2 pound magnet in with BFH
Step 3 order new magnet coz you smashed the first one to peices with hammer
Step 4 drill rim of trigger wheel coz hole for magnet in wheel face is now mangled beyond use
Step 5 glue magnet in with old CA
Step 6 watch magnet fly into the next county
Step 7 order new trigger wheel
Step 8 get new magnet
Step 9 follow above advice.
Old 01-23-2010, 01:33 PM
flyrc100
My Feedback: (131)
Hmmm, The south pole needs to face sensor, dumb question, how do I figure that out? Thanks
Old 01-23-2010, 02:21 PM
WildeOne
You need a known polarity magnet (i.e a compass will do fine), opposites attract, same repels.
Old 01-23-2010, 02:31 PM
Nosedragger
just run it by sensor with everything connected and grounded properly and ignition on, when it sparks its the right polarity
Old 01-23-2010, 02:53 PM
WildeOne
That works as well.
Old 01-23-2010, 05:19 PM
dogshome
dogshome's Avatar
ORIGINAL: Nosedragger
Step 1 drill hole for magnet .010'' undesize
LOL Great post
Old 01-23-2010, 07:37 PM
flyrc100
My Feedback: (131)
The hook it up and try it thing worked, glad someone said something before I smashed it in place! Actually the magnet works with reverse roation if its upside down.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
