Echo and Stihl
Old 08-14-2010 | 12:37 AM
av8tor1977's Avatar
Default Echo and Stihl
Hi guys,
These two engines, a Stihl 27cc and an Echo 21cc, both all converted and literally ready to fly are listed for sale here in RCU. Check the ads and e-mail me.
AV8TOR
ID:	1483648   Click image for larger version
Old 09-08-2010 | 01:50 PM
av8tor1977's Avatar
Default RE: Echo and Stihl
Hmmm, don't know what happened to the other posts in this thread.
Anyway, the Stihl was sold, and the Echo was re-listed at a lower price. It only has about a day left on the listing, and it won't be listed again.
What brand/size engines would you guys be interested in converted and ready to go?? I can't afford to buy ignition units for them, but I could offer them "ready to install ignition" if that's what the demand is...
AV8TOR
Old 09-08-2010 | 02:10 PM
w8ye's Avatar
My Feedback: (16)
I can not see any evidence of there ever being any other posts in this thread??
Old 09-08-2010 | 03:25 PM
Actually I posted responses to the original notice that these engines were for sale. I can't find them anywhere. Were they deleted? Regards,
Richard
Old 09-08-2010 | 04:04 PM
w8ye's Avatar
My Feedback: (16)
You guys are just not looking hard enough
http://www.rcuniverse.com/forum/m_99...tm.htm#9952640
Old 09-08-2010 | 04:12 PM
av8tor1977's Avatar
NOW I remember. We had two threads going about the same thing. Thanks W8YE!
AV8TOR
Old 09-08-2010 | 04:16 PM
w8ye's Avatar
My Feedback: (16)
Up until August 2004, I could combine threads, split out a post and make it a new thread or stick it in another thread but no longer can do
Old 09-08-2010 | 10:04 PM
buck1856's Avatar
My Feedback: (49)
Theres a couple items for sale here in the market place that if they dont sell,ill be giving them away for free.
Just pay shipping.
If interested,pm or email me.
There will be more added.
Old 09-08-2010 | 10:37 PM
av8tor1977's Avatar
Have sales been dismal for you too Buck? How have you been doing?
AV8TOR
Old 09-09-2010 | 12:58 AM
buck1856's Avatar
My Feedback: (49)
Yes,badly.
I even tried to sell a Husky,completely converted,the only thing it needed was the hall sensor.
I even had the mount made up.Just install the sensor.61cc.
Asked me if the ign was included.I said no,and never heard from him again.
I lowered the engine to 69.00 dollars for him.
Old 09-09-2010 | 06:16 AM
ORIGINAL: buck1856
Yes,badly.
A 61cc huskavarna (sp?) aye? I assume it's a full crank engine? How much does it weigh? Probably waaaay too big for azippkits46" easy V....lol
Old 09-10-2010 | 01:42 AM
buck1856's Avatar
My Feedback: (49)
Its full crank,weighs 5.25 lbs.
The nice thing about it is i can go get a new piston and jug for a 68cc for $99.00,
and just swap it out.
Wich is what ill probably do and then sell it to my son for what i have into it for his 1/3 scale DVIII.
Its a scratch built from Bill Wendt plans.104 inch WS.
Hmmmmm,maybe to small.
Old 09-10-2010 | 07:26 AM
Are you still in the market to sell? If not I totally understand - Im building the EasyV for my son - he's 9 months old now, so I have some time to finish it! lol!
Hmm when I get home I'll have to weigh the ryobi 31cc I'm planning on putting into the EasyV.But 5.25# isnt much more comparatively... What are the rough dimensions? Got any pics? nelson390 AT hotmail.com.
Old 09-12-2010 | 01:12 AM
buck1856's Avatar
My Feedback: (49)
sent ya PM.
Ill get back to ya.
What else are you looking for in size and weight,and dimensions.
I have an echo 45cc laying around,but not ready to run at all.
Just started the conversion basiclly.
Pm me.
Old 10-30-2010 | 02:26 AM
My Feedback: (9)
Got my Stihl stripped down. Where can I get the prop adapter?
ID:	1525221   Click image for larger version
ID:	1525222   Click image for larger version
ID:	1525223   Click image for larger version
ID:	1525224   Click image for larger version
Old 10-30-2010 | 11:34 AM
My Feedback: (13)
are the threads on the crank left or right hand? they are probably 8mm or 5/16", I could make one for you if you want...
Old 10-30-2010 | 01:45 PM
My Feedback: (9)
ORIGINAL: rangerfredbob
are the threads on the crank left or right hand? they are probably 8mm or 5/16'', I could make one for you if you want...
Threads are normal right hand. Righty-on,lefty-off. Pull starter rotates the crank CCW. Nut measures 8mm, as close as I can tell with my inside calipers. Can you make a backing plate also?
I was thinking of pulling the head to get a better look at piston and walls. Piston has 2 rings. Will I need a ring compressor to
put it back on? I have trimmed down the flywheel and attempting to balance it on my prop balancer.
Anything else I should be aware of?
Thanks for your help,Dennis(from Eugene)
Old 10-30-2010 | 03:10 PM
w8ye's Avatar
My Feedback: (16)
A ring compressor is rarely needed
Old 10-30-2010 | 04:24 PM
In lieu of a special ring compressor, if one is needed, just use a gear type hose clamp and put it around and tighten against the rings, Don't tighten so much that the clamp won't slide on the piston, just enough to compress the rings. If your clamp is not big enough use two coupled together. Insert the top or bottom of the piston into the bore until the clamp comes up against the cylinder. Then carefully push the piston and rings into the bore, allowing the hose clamp to slide free of the rings. Simple and effective.
Sincerely, Richard
Old 10-30-2010 | 10:42 PM
My Feedback: (13)
no ring compressor needed, just compress the rings with your fingers while you put the jug back on.
try measuring the outside of the threads then the thread separation, 8mm and 5/16 are nearly identical so they are hard to identify by just the outside diameter.
I could make a backplate mount, but I never use them as it's just extra weight where that engine has a perfect mount from the factory, just cut the back shaft off with a dremel or something but carefully so as not to overheat the seal.
Old 11-01-2010 | 08:25 PM
My Feedback: (9)
The threads are normal right-hand.1.25 pitch. 8MM
The recessed area is a little under 1 inch. (see pic.)
ID:	1526946   Click image for larger version
Old 11-02-2010 | 07:37 PM
My Feedback: (9)
I'm confused! It doesn't take much!
I have a Stihl FS76.Can't find cc specs for it. Nice and lightweight, will be a nice conversion
Also have a FS81. Much heavier.4 bolt pattern on cylinder and pull starter.
According to Stihl's website it's has 22.5 cc displacement. Does this sound right?
Might be too heavy for conversion.
Has anyone had experience with these 2 motors?
Another conversion question.
Is the Echo 3800 weedeater too big for gasser conversion?
I've read that the 2400 is a good one for cconversion.
Old 11-02-2010 | 09:02 PM
w8ye's Avatar
My Feedback: (16)
The 3800 is like 37.4 cc. and would be a nice size model engine but I don't know about the weight?
The plug is up in a penthouse
There's a big fan housing that has to be sawn away.
Old 11-07-2010 | 04:04 AM
My Feedback: (9)
Echo GRM-2400 weedeater won't stay running.
Just got it today. Cleaned carb, (didn't rebuild,) bypassed gas tank,
Primer bulb is good. BUT,engine won't keep running.
Might I have a air leak? Bad seal? What is the best way to test for leaks?
What is the purpose of the little red plastic plugs over the needle valves?
Something to do with DEQ? Should I remove them?
Thanksfor any pointers given.
Dennis
Old 11-07-2010 | 09:55 AM
w8ye's Avatar
My Feedback: (16)
The red plugs on the needles should just pop off. They are travel limiters
