RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   converting a .21 nitro to spark ignition (https://www.rcuniverse.com/forum/engine-conversions-92/10075869-converting-21-nitro-spark-ignition.html)
sam123 10-18-2010 05:11 AM
Hi everybody, this is my first time posting in this particular forum (I usually stick to the giant scale cars forum).
For a while now I have been thinking about converting a .21 engine out of a 1/8th scale buggy to spark ignition. I have done alot of searching and found lots of good info regarding the conversion of airplane engines, and am amazed at how well they run. I understand that the engines run hotter on gasoline, make a bit less power and require more oil in the fuel than your typical zenoah. None of this worries me, as this is really just an experiment...I just think it will be cool to have such a small engine running on pump gas :D
There are just a few things I am unsure about:
First of all, I see that the engines you guys are converting are much bigger than my engine. Would there be any major problems with converting a .21? Im guessing the higher revs might have something to do with this.
Secondly, why is it that there have been no car/buggy engines converted to spark ignition? If anyone has any info/pictures of converted car engines I would love to see them :)
Finally, these are the parts I am looking at using for my conversion:
cdi : http://www.unitedhobbies.com/UNITEDH...idProduct=6292
hall sensor: http://www.unitedhobbies.com/UNITEDH...idProduct=7868
spark plug: http://www.dlenginesaustralia.com/dl...&productId=127
magnet: http://www.dlenginesaustralia.com/dl...&productId=305
Should this combination of parts be ok? I realise I will have to make an adapter for the spark plug cap ;)
Any help would be greatly appreciated.
Sam.
sam123 10-18-2010 07:15 PM
RE: converting a .21 nitro to spark ignition
Uh...so it looks like Im on my own then [:o]. I thought somebody could have helped...
Oh well, im gonna give it a shot anyway :).
kp96 10-18-2010 07:56 PM
Um im trying the same thing but with a .15 engine im still looking for parts but im in need of help.
sam123 10-18-2010 08:23 PM
What parts are you looking for? I think all the stuff you need is the cdi, hall sensor, magnet, 1/4"-32 spark plug and a 4-cell reciever pack. Links to the parts I plan on buying can be found in my first post. A walbro carb might be needed to, but I doubt we will find one small enough for our engines. Im not really of much use other than that sorry. Once I have got my parts and given this a shot I will let you know if I get it working or not.
Is your engine a for a car?
kp96 10-19-2010 06:34 AM
Yes its for a nitro rustler
thanks
kp96 10-19-2010 06:37 AM
but im looking at a gas engine cylinder and puting it on a glow so the walbro carb will fit.
Nikolas K 10-19-2010 08:58 AM
ORIGINAL: sam123
Sam.
Sam,
You are driven by the same motivation that has driven me in converting an ASP .52FS into a gasser. Watch my videos in Youtube if you want. The engine runs extremely well and now I am willing to fly it also, however I have to find the time to install it in the airplane. Anyway, for your engine:
It is indeed a small engine to convert. My idea is that a .50 engine and up is most suitable, as in smaller engines the weight of batteries and ignition system becomes an issue. However, if you want to convert to a gasser, it can be done (imagine, in the '20s, '30s and '40s, before the glow plug invented, there were as small as 0.09 gassers and people were still flying-of course without radio control systems and with large span, slow, airplanes).
As I can see, most of the parts needed are there. However, you need to manufacture a spark plug boot, if you buy this ignition unit. You might also want to consider RCEXL ignition modules for 1/4-32 spark plugs, whose spark plug boot is already there!
Also, the greatest challenge you will face, during conversion according to my opinion, is placing the magnet on the small propellor hub of a .20 engine. It might even bee too big (the magnet) for being properly glued in place...But I do not know your engine exactly, so I cannot imagine your hub.
The timing of the ignition is straightforward, if you have a degree wheel, but another challenge would be placing the sensor holder on the engine. Again, I do not know how you are going to do it, but I used a hose clamp and glued the sensor holder on it. Thus, ignition timing is adjustable, which is a good idea if you make it adjustable as well. My engine needed to lag the ignition some degrees in order to start and work properly without backfires (I haven't reduce the compression).If I had fixed the sensor holder, I would not be able to do so.
If you have more specific answers, do not hesitate to ask.
optech 10-19-2010 01:25 PM
I've not been following .21 size engine development but aren't they all ABC style construction nowadays? If so, they wont last long on Gasoline fuel. The ABC construction is pretty temperature specific when running. Gas burns hotter so I wouldn't expect the engine to last long. Look for a ringed type engine if you really want to do this.
Mike
sam123 10-20-2010 04:02 AM
ORIGINAL: Nikolas K
Sam,
Thankyou for your reply!
Thats a good point you make about the old engines running spark ignition. I always just assumed they were nitro.
The weight of the system dosen't really bother me, as this is just an experiment i've wanted to do for a while. Later on I might end up buying a bigger, ringed heli or plane engine and modifying it to use on an rc car.
I think I should be ok with placing the magnet in the flywheel, as I was going to make a new flywheel for it anyway on my mini lathe. I also plan to cut a groove into the circumference of the flywheel and use it as a drive pulley for a cooling fan....but that can wait I guess. And I will definately be making the mount for sensor adjustable, thanks for the tip!
sam123 10-20-2010 04:14 AM
ORIGINAL: optech
Mike
Hmm, the engine I have is of ABC construction, like you mentioned. I guess this could cause some problems [:@]. Do you think I could avoid this by keeping it as cool as possible (using a cooling fan and avoiding full throttle), and use a higher oil content? If the engine does end up dieing, I will definately upgrade to a bigger, ringed engine.
kp96 10-20-2010 06:34 AM
I thinking of buying a Fuji Imvac gasoline cylinder which is 24cc will it fit a traxxas 3.3 crankcase?
sam123 10-20-2010 06:45 AM
No, sorry. There is no way that could work.
Nikolas K 10-20-2010 01:34 PM
ORIGINAL: sam123
ORIGINAL: optech
Mike
Optech, is right. This is a point I 've forgotten to mention to you. Conversions work better for ringed engines. But then again, in the years before glow plug, the small engines at least were not ringed. And I have seen many plans and patents of old engines (like the Atom and 0.099 of Arden design) and I haven't noticed a ringed piston. Neither a ball bearing in the con-rod... And considering the materials available back then, I assume all these made it worst.
I think that by going conservative (i.e at least 14:1-15:1 gasoline-oil mix, rich settings, sufficient cooling) you will not have a problem.
After all, the worst that can happen for an ABC engine is to increase the clearance between piston and sleeve and lose power, or stall the engine. It has the characteristic that it cannot "stick together", because Brass sleeve expands more than the aluminium piston and so you are protected from sudden destruction. The best of course is to have the metals already stabilised, i.e. have the engine run-in with glow fuel and glow plug.
As for longevity of the engine is considered however, keep in mind that increased temperatures and less lubrication may cause the converted engine to wear before the glow version. How fast, I do not know. My experiment is still ongoing for the four stroke...
Try to convert a cheap engine as this is an experiment. You didn't tell us which engine you are thinking of converting.
kp96 10-20-2010 02:11 PM
will a size 14cc-50cc walbro carb fit a nitro rustler
Jezmo 10-20-2010 03:38 PM
The "real old" spark ignition engines had a different metallurgy than todays modern ABC/ABN screamers. Typically the cylinders were steel and the pistons were cast iron but fear not the little .21 will run for a while. Eventually the piston to cylinder seal will deteriorate enough that it will become hard to start but that will take a while especially if you keep the fuel/oil ratio rich. I'm running my ringed SuperTigre's at 16:1 but I'd go for something more in the 10 to 12:1 range on the ABC stuff. Set the timing up around 28 degs BTDC, + or - a deg or two and she'll run good. Also, remember the carb is going to need to be significantly leaner than with glow fuel. (it takes 2.3 times more methanol than gasoline to have a stoichiometric mixture) The needles will be quite sensitive with only a click or two being the difference between very rich and very lean on the high needle, the low needle being equally sensitive. Good luck and remember to have fun, after all, that's what it's all about.
P.S. Be safe and remember the voltage discharge from the CDI is quite high and can hurt you.
kp96 10-20-2010 05:24 PM
but can i put a walbro carb on traxxas 3.3 engine. do i need a walbro carb on a traxxas 3.3engine for a glow to gas converstion
w8ye 10-20-2010 06:07 PM
ORIGINAL: kp96
I've run big glow engines on gas using the original glow carb
kp96 10-20-2010 07:49 PM
so it should work but what is the diffrence but will a Walbro car tht fits until 14cc fit a traxxas 3.3.
captinjohn 10-20-2010 10:11 PM
For the magnet install...machine a ring that slips on the flywheel or hub. Install magnet in ring and a small setscrew on the opisite side of the ring. To get the right timing...just loosen set screw...and turn ring a tad.
The carb may be tricky.But a regular glow carb may work if it will draw fuel & if the needle is not to touchy to adjust. Look up a small RC car that was made in Italy. It was about the same cc & was gas with CD ignition. Capt,n
http://www.classic.rc-junkies.net/?page_id=637
sam123 10-21-2010 05:34 AM
Thanks for all the help guys :) .
So I guess the piston and liner should be ok as long as I use more oil than usual. Maybe once I get it going I could experiment with different fuel-oil ratios and oil types.
Nikolas, the engine I plan on converting is a Thunder Tiger .21 Pro. Apparently it is a re-badged OS engine. So, the quality is not too bad. It has not been used much, but has already been broken in on 5% nitro.
Jezmo and captinjohn, I am fairly confident that the carb will be ok. It dosen't use the same 'click' system as the plane engines, but fully adjustable screws like on the weed eater engines. I do have a few spare walbro carbs, but the smallest I have is from an 18cc weed eater, so it would probably be too big.
And yes I know what you mean about being careful with the cdi :D. Ive been shocked a few times by my weed eater engines and wow did it hurt.
Also, captinjohn, I will have to take a look at that engine you speak of! Sounds very interesting . And thanks for the link.
I have another question for you guys: How much does the entire cdi system weigh, including the battery (approximately)? Could the cdi be run off the reciever battery if I use higher capacity cells?
kp96 10-21-2010 06:41 AM
Also What is the hall sensor work. Also what was the website for the car.
kp96 10-21-2010 07:01 AM
also the will i have to change the gaskets.
w8ye 10-21-2010 08:47 AM
Normally no
optech 10-21-2010 02:11 PM
ORIGINAL: captinjohn
The carb may be tricky. But a regular glow carb may work if it will draw fuel & if the needle is not to touchy to adjust. Look up a small RC car that was made in Italy. It was about the same cc & was gas with CD ignition. Capt,n
They're sold here in the states through MECOA http://www.mecoa.com/compagnucci/index.htm I've always wanted to inspect one of these and see if anything is transferable to other planes or cars but WOW..... they are expensive just be poking around on.
kp96 10-21-2010 02:43 PM
Ok i got the spark plug and the cdi also the 4 cell battery and the hall censor for my traxxas 3.3. by the way whats the hall censory for. Also wats the ratio gonna be for gas to 2 cycle oil. And how will i ignite the engine.
kp96 10-23-2010 08:50 AM
how do i ignite the engine
Nikolas K 10-23-2010 09:58 AM
ORIGINAL: kp96
What do you mean?[sm=confused.gif]
kp96 10-23-2010 10:04 AM
Like i how will it work.
Nikolas K 10-23-2010 10:06 AM
ORIGINAL: sam123
The weight depends apparently on which system you will purchase. The Rcexl system weights 4.4oz, without batteries. The battery pack is a normal 4.8V Rx pack.
I would not recommnend using the receiver's battery pack for the ignition. Noone would recommend it. It can cause neither system to operate adequately. Just use two battery packs, even though as the airplane size decreases, the extra weight becomes an issue. (that's why most people convert engines more than 0.60 cu.in, which are used by big airplanes.)
rangerfredbob 10-23-2010 12:13 PM
you use a separate power switch harness for the pwer for the ignition, turn the switch on and the ignition turns on, turn it off and the engine will turn off.
you will probably have better luck putting the ignition on the engine and running it on glow fuel, this can give you better performance than a glow plug with better reliability, if you get the bugs worked out that way change the fuel lines and maybe try gas.
sam123 10-26-2010 08:06 AM
Well thanks for all the help guys.
So it looks like I will be using two battery packs then. And to make things easier I will get it running on glow fuel first. Gotcha :)
I still have a few litres of glow fuel left over anyway. Better use it before it goes stale [:@]
Just to let you know, I will be buying the parts for it this weekend. I can't wait to start working on this :D
gkamysz 10-26-2010 10:05 AM
Some of this has already been covered.
The ignition has a maximum RPM above which it will provide progressively weaker spark or not spark at all. RCEXL doesn't specifically publish this RPM. We do know they run up to 15k just fine. I would bet it can do 18-20k, but haven't tried. As mentioned above fitting the sensor and magnet will take some work and probably a custom sensor mount and smaller than typical magnet. Unless you can get an ignition with a straight plug boot or make one, you won't be able to get the boot onto the plug deep inside the heatsink head.
Gasoline will have much less power than the typical 20-30% nitromethane glow fuel.
The engine will run much hotter on gasoline. What this will do to the ABC piston and liner fit or life is for you to find out. Oil ratio should be similar to the glow fuel being used, or potentially even more. Use a high temp, high viscosity racing oil.
The carb is designed for the above mentioned glow fuel, on gasoline adjustment will be tough. If it has two needles the idle and WOT throttle can be tuned fairly well, but midrange will be rich, probably very rich. A "third" needle is unlikely to help much in this case. It will be very sensitive to needle adjustments. The difference in a car application compared to an airplane for a carb is that the engine will be operating in a wide range of RPM for a given throttle setting such a simple carb has a hard time dealing with that. It works well with glow fuel because it tolerates a very wide range of air fuel mixture. Gasoline is much more critical. The glow carb will likely also be too large for gasoline. With a slide carb it's fairly easy to just limit WOT as long as this doesn't interfere with tuning the needles.
Nikolas K 10-26-2010 01:58 PM
ORIGINAL: sam123
Bear in mind, that using glow fuel might dictate alteration of the static ignition advance (ie the angle you set the spark when you turn by hand). When using gasoline, this angle is usually 28-30 degrees Before TDC.I do not know how much it should be when trying glow fuel, which has different flame propagation speeds. The guys who are trying spark ignition with glow fuel may help you.
