RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   So why is it that..... (https://www.rcuniverse.com/forum/engine-conversions-92/10173010-so-why.html)
Scota4570 12-02-2010 07:51 PM
On twins almost everyone blocks off the intake ports and installs a single reed block? It would seem to me that simply putting plates over the intake ports would not be a great idea flow wise. It also seems to me that dual carbs is not a big deal to set up. Maybe 2-strokes are different but my old VW was very easy to set up with dual Webbers. Making linkage on a one-of basis might be challenging but for a semi production engine it would not be a problem. Hmmmm?
rangerfredbob 12-02-2010 10:10 PM
RE: So why is it that.....
they generally use one large carb because of weight savings, everyone in the rc airplane world wants to save any weight they can lately
Thomas46 12-03-2010 05:55 AM
It is a difference if you are talking about Boxer or In-line engine.
Boxer (Flat twin) 2-Stroke engines uses the same Crankhousing room. So it makes no sense to use 2 carbs. One is enough.
In-Line 2-Stroke engines have single crank house space. Both chambers are seperated by the middle bearing with seal ring.
Here you can use 2 carbs. But mainly the manufacturers uses Y- intake header. Cheaper, but there is space for some tuning.
spaceworm 12-03-2010 06:45 AM
ORIGINAL: Scota4570
My '66 Porsche 911 had two triple throat Solex carbs, and the Porsche mechanic did not complain very much, but did charge a lot for their tuning. My British twin SU carbs were never in tune. You used a piece of tubing with one end in the intake and the other end in your ear.[&o]
Sincerely, Richard
