30cc POPE Pusher.
Test running one of the engines I have converted, prop adapter on the pull start side so it can be run as a pusher motor. 16X8 groupner Super Nylon. Flick starts easily. [youtube]http://www.youtube.com/watch?v=jlXi6YMwzLU[/youtube]</p> |
RE: 30cc POPE Pusher.
Hey, how does that tach work and where did you get it? Engines sounds great!
AV8TOR |
Hey Av8tor,
its a TTO tach. I got mine from here( www.dasboata.com) I believe they can be purchased from motorcycle shops aswell. Simply wrap the signal wire around the plug lead. tacho can then be mounted anywhere on the model. A lot of the boat guys use them, once you shut the engine down it will display max rpm for about 10 seconds then switch back to run hours when not in use.For tuning purposes it was the best $30 I ever spent, chasing that last few hundred rpm. http://www.rcuniverse.com/forum/js/f...wink_smile.gif |
Ah, ok. I didn't see the wire. I am familiar with that type of tach with the small wire to the spark plug. But having not seen the wire, I thought it worked on vibrations or something. I believe they do make some sort of a vibration tach....
Thanks and good luck with your project. Please post pics as you go... AV8TOR |
| All times are GMT -8. The time now is 04:28 AM. |
