RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   Frank Bowman Piston Rings (https://www.rcuniverse.com/forum/engine-conversions-92/10607246-frank-bowman-piston-rings.html)
captinjohn 07-05-2011 12:25 PM
Here is a new price list for Franks Custom rings.
<hr />Email: [email protected]</p>
</p>
</p>
</p>
Reproduction Model Engine Rings</p>
</p>
Quality at a fair honest price. Making a good ring is a Skill. Making a fine ring is an Art!</p>
</p>
</p>
</p>
Last Revised 7 - 4 -11</p>
I will reproduce nearly any model engine ring. If not available, I&rsquo;ll need a good piston and cylinder to measure, or send motor. Send return postage, insurance is extra. For orders outside of USA, ask for shipping costs? Priority postage is extra. An order of 10 rings or more, discount of $1.00 off per ring, mixed orders are fine! Ring cost &amp; shipping charges for USA listed below.</p>
Please Note:</p>
If you send me an engine for new rings that I don't currently make there will be No labor charge to do this.</p>
If you send me the stripped down engine block ( Block, piston liner and rod assy.) for rings, that I Do currently make No extra charge.</p>
If you send me a complete engine to disassemble, clean, and install the ring(s) and reassemble there will be a minimum charge of $25.00 per hour. My buisness is making Piston Rings and $25.00 is the minimum amount I would be losing by not making rings and working on your engine instead.</p>
ATTENTION : NEW MEXICO CUSTOMERS WE HAVE TO CHARGE YOU 7.125% TAX, please add the extra tax to your orders.</p>
Standard ring up to .29 size $9.00 ea. N.M tax rate (1) .64 (2) $1.28</p>
Standard ring .30 to .65 engines: $10.00 ea. " (1) .71 (2) $1.43</p>
Standard ring .66 to engines up to 1.999 bore: $11.00 ea. " (1) .78 (2) $1.57</p>
Standard ring with 2" bore to 2.999 bore $12 ea. " (1) .86 (2) $1.71</p>
Dykes ring up to .29 size $10 ea. " (1) .71 (2) $1.42</p>
Dykes ring .30 to .65 engine: $11.00 ea. " (1) .78 (2) $1.57</p>
Dykes ring .66 to engines up to 1.999 bore: $12.00 ea. " (1) .86 (2) $1.71</p>
Dykes ring 2" bore to 2.999 bore $13.00 ea. " (1) .93 (2) $1.85</p>
</p>
Shipping per order $4 First Class anywhere. Priority in USA only $5.90, both with delivery conformation. For out of US shipping charges other than First Class, email for more options.</p>
</p>
</p>
** I also make special rings to order, ask for prices.**</p>
Ace Twin .64</p>
Aero .35</p>
Aerrow 100 (pin) Quadra</p>
Aerrow 200 (pin) Quadra</p>
Aerovat 65 CC (pin)</p>
Aircom M61 (pin)</p>
Air-O .45</p>
Anderson Spitfire .65</p>
Area 51CC (pin)</p>
Asp .52 4C, .61 (pin), .65 4/C, .80 4/C, .91 4/C</p>
Atomic 60 Don Sohr</p>
Atwood .49, .51, .63</p>
Avion Mercury 1.609</p>
Avistar .60 (pin)</p>
Bantam .16</p>
Bat .19</p>
Bennelli 65 CC (pin) motorcycle</p>
Berilli 36 CC (Pin)</p>
BME 3.5 Twin (pin), 105 (pin), 110 twin (pin)</p>
Brillelli 60 CC (pin)</p>
Brison 2.4 (pin), 3.2 (pin)</p>
Brown Jr. .60 cylinder sizes vary (send Piston &amp; cylinder for proper fit &amp; correct ring)</p>
Brownie .29</p>
Bushwacker 37.7 CC (pin) Sears</p>
Bunch .45, .49</p>
Cameron .15, .19</p>
Cave Cobra</p>
Chung Yang 29CC (pin)</p>
Cleveland Tom Thumb .45</p>
Comer 50CC (pin)</p>
Como .29 (pin), .40 (pin), .51 (pin), .90 (pin)</p>
Contestor D.60</p>
CRRC Pro 26CC (pin), 40 CC (pin), 45 CC (pin), GF 50 i (pin)</p>
CS .53 (pin)</p>
Cub Cadet 25CC (pin)</p>
DA 50 CC (pin) (2) different 1.678 Bore, &amp; 1.681 Bore</p>
DL 50 CC (pin)</p>
DLE 20 CC (pin), 30 CC (pin), 55 CC (pin),110 Twin (pin), 170 Twin (pin), 222 4 cylinder (pin)</p>
DME 100 Twin (pin)</p>
Dooling .29, .61, Yellow Jacket</p>
DZY 48 CC Twin (Pin)</p>
Echo 16CC (pin), 21CC (pin), 21.2 CC (pin), 24.4 CC (pin), 30 CC (pin), CS-3000 (pin), 50 CC (pin)</p>
Edco Sky Devil .64 Old or New (RJL) state which one?</p>
Elf Andrea Heine Repo</p>
Enya 3.5 (pin), .30 SS (pin), .35 X (pin), .40 X Dykes (pin), .40 Dykes model 6002, .40 4/C, .45, .45SS (pin), .46 4/C,.49 X (pin), 50SS (pin),.53 4/C, .60 4/C, .60 X (pin), .60 standard, .61 CXLR (pin), .80 X (pin), .80 4/C, .90 4/C, 120 4/C, 120 R 4/C, 1.55 4/C, 240 4/C Twin</p>
ETA .29</p>
EVO 150 Twin (pin)</p>
EVRA 190</p>
Forster .29, .31, .88, .99</p>
Fox 36 Sand Cast (pin), .40 Sch., .45, .50, .59 .047 thick ring and .030, .59 long shaft Ign., .60 Blue Head, .60 Eagle, Eagle II .60 (pin), Hawk</p>
Red Head .60 (pin), .74, .78, 120 Twin (pin), Gas Bore 1.439 ? (pin)</p>
Fuji 43 CC EI (pin)</p>
GMS .61 (pin), .61 Dykes (pin), .76 Dykes (pin), 1.20 Dykes (pin)</p>
Hassad Blue Streak .64</p>
HB .21 Dykes,.25 Dykes, .40 PDP Dykes, .40 Black Head (pin), .50 Dykes, .61 (pin), .61 Dykes</p>
Hiller (Car)</p>
Hirobo 36 (pin)</p>
Homelite 25 CC, 30 CC (pin) old .060 thick pin centered (press in ) , 30 CC newer .030 thick (pin), 30 CC new style Off set pin, 33 CC (pin), 38 CC (pin), 40.6 CC Super EZ Chain Saw, Super Mini Chainsaw Dykes (pin), 45 (pin), 50 CC (pin)</p>
Horner 3.7 Twin (pin)</p>
Hornet .19, .60</p>
Howler .60 (pin)</p>
HP .21 4/C Dykes ,.40 (pin) ,.61 R.I. Silver Star (pin), .61 Dykes (pin) Blk Case Gold Hd.</p>
Hurluman 60</p>
Husqvarna 2100 (pin) Chainsaw Pin needs pressed in 1/2 way</p>
Irvine .20 Dykes, .25 Dykes, .36, .40 Pylon Dykes (pin), .40 Standard (pin), .46 MKII Q46 Dykes, .61 Dykes, 120 Dykes, 150 standard non pin.</p>
JC Evo 28 CC (pin)</p>
Kavan MK 50</p>
Kaw T5A 60 CC (pin) Artic cat Snowmobile</p>
KDC Kioritz 21.2 CC (pin), 23.6, 25 CC (pin), 30 CC (pin), 58 CC (pin)</p>
K&amp;B .35 Dykes, .40 Dykes, .40 S Dykes (pin), .61, .61 Dykes (Lee Custom), 1.35 (pin), 1.5 (pin)</p>
Kometa 29</p>
Kraft .61 (pin)</p>
Kratmo 10 CC, 4A Ignition</p>
Laser 61 4/C</p>
Lewis 60</p>
Magnum .52 RFS 4/C, .53 XL 4/C, .61 XL (pin), .61 4/C, 70 4/C, .91 XL 4C, 120 4/C, 120 (pin)</p>
Maloney 100 (pin), 125 (pin)</p>
McCoy .09, .19, .19 Dykes B.H., .21 Dykes Car, .29 all versions, .29 Dykes B.H., .35 Dykes B.H., .36, .40 Dykes B.H., .49, .55, .60, .60 Dykes</p>
McCulloch 15 CC ? (pin) 1.024 Bore, 21 CC (pin), 25 CC (pin) MDB 90 Leaf Blower, 28 CC, 32 CC (pin),</p>
MDL 28 CC (pin)</p>
MDS .78 (pin), 1.48 (pin), 2.18 (pin)</p>
Merco .40, .49, .49 Dykes, .50, .61, .61 Dykes</p>
Micron 60</p>
Moki M .51 (pin), .61 (pin), 1.20 (pin), 1.35 (pin), 1.50 (pin), 1.80 (pin), 2.10 (pin)</p>
MT 42CC (pin), 57 CC (pin)</p>
MVVS .40 Dykes (pin)</p>
O&amp;R Industrial Motor 1 HP</p>
OPS Maxi .30 (pin)</p>
OS .20 FS 4C, .26 4C, .28 FH Dykes (pin), .30 fs 4/c, .32 (pin), .37 H (pin), .40 H Dykes, .40H Standard, .40 H (P) Pylon, .40 FS 4/C, .40 SF (pin), .807 bore, .40 SR (pin), .40 FSR .835 Bore (pin), .40SR Dykes (pin), .45 FSR (pin), .45 FSR Dykes (pin),.45 RSR Dykes, .46FX (pin), .46SF (pin), .46 4/C, .48 4/C Surpass, Max .50 old, .50 FSR Dykes (pin) ,.50 H (pin), .50 SX &amp; SXH (pin), .52 4/C surpass, .58, Max-H .60, .60 FS 4/C, .60 FSR (pin) .9445 Bore ,.61 SF .9055 Bore (pin), .61 FS 4/C, .61 SX (pin), .61 SXH (pin), .65 RSR (pin), .70 4/C, .75 4/C Surpass, .80 H,.80 Dykes (pin), FS.90 4/C, .91Surpass 4C, .90 FSR (pin), .91 FSR (pin), .91 FX (pin), .91 SX H (pin), 1.08 BX-1 (pin), 120 4/C, 120 twin 4/C, 120 AX (pin), 160 FX (pin), 160 4/C, BGX-1 3500 (pin)</p>
Poulan 25CC (pin), 25 CC Featherlite (pin), 32CC (pin), 35 CC (pin), 42 CC (pin), 42 CC Wildthing (pin), 46 CC (pin), 54 CC (pin), 60 CC (pin)</p>
Pioneer Grass Trimmer Model B 440, 42 CC (pin)</p>
Profi .40 (pin), .61 (pin), .76 (pin)</p>
Quadra 35 CC , 40 CC (pin), 42 CC (pin), 50 CC (pin), 100CC Aerrow (pin), 150 Twin (pin) , 200 CC Aerrow Twin (pin)</p>
Quick Draw CC (pin)</p>
RCGF 20 CC (pin), 32 CC (pin), 45 CC (pin)</p>
RCS 1.40 (pin)</p>
Ross .60 Dykes (pin), .60 opposed twin Dykes (pin), .61 (pin)</p>
Rossi Speed .60 old, .60 (pin) .021, .61 (pin) .023, .65 (pin) .0235, Speed .65 (pin)</p>
Royal 40 (pin)</p>
Ryobi 26 mm Bore EJ 100 (pin), 31CC (pin) older .064 thick, 31 CC (pin) newer .047 thick</p>
Saito FA .30 4/C, .40 4/C, FA .45 4/C, FA .50 4/C, FA .56 4/C, FA .60 Twin 4/C , FA .62 4/C, FA .65 4/C, 72 4/C, FA .80 4/C, FA 82 4/C, .90 4/C, .91 4/C, 100 4/C, 120 4/C, FA125 Golden Knight 4/C, FG 20 125 4/C, 130 TD 4/C Twin, 150 4/C, 180 4/C, 270 4/C Twin, 300 4/C Twin</p>
Sachs 2.0 (pin), 3.2 (pin) offset, 3.2 (pin) centered, 5.8 (pin)</p>
Sap-180 HP 1.2 (pin)</p>
Scott Thunderbird</p>
Sears Weedeater, Bushwacker,18 CC, 21 CC, 25 CC, 25 CC TWC Leaf Blower, 37.7, all pinned, 1966 Allstate Moter Cycle engine made by Puch (pin)</p>
Shindiawa 33 CC (pin)</p>
SIFK 29CC (pin) AKA CY, Chun Yang</p>
Skil chainsaw (pin)</p>
Sky Chief .53</p>
Solo 2/C tiller approx. 20CC (pin)</p>
Spe 25.4 (pin), 26 CC (pin), 40CC (pin), 45CC (pin)</p>
Stihl 25.4 (pin), 028 Chain Saw 44 CC (pin), Super 45 (pin), 57 CC (pin), MS 440 Chainsaw 70 CC (pin)</p>
Super Tigre G20.15, G20 .19, G20 X.25, S .29 (pin), G21.29 old, .34 (pin), .40 Bullring, S.40 (pin), G21.40 std., G21 .40 Dykes, G21.46 std. ,S.45 (pin), V.45, X.45 (Pin), G21 .46 wide Dykes, G.46, G .46 Bullring, V 51, G51 (pin) Italian, G51 (pin) China, V.56, V.56 Dykes, V 60 light case .044 or .047 top to bottom measurement, G24 60 Old, G 60 Bluehead, X60 (pin), V.60 wide &amp; narrow Dykes, S.61</p>
(pin), G.71, S.75 (pin) Italian, S.75 China, G.90 (pin) Italian, G.90 (pin) China, 2000 (pin), 2300 (pin), 2500 (pin), 3000 (pin) Italian, 3000 (pin) China, 3250 (pin) Italian, 3250 (pin) China, 4500 (pin)</p>
SV 50 CC (pin)</p>
Syncro B-30, Syncro ACE, Syncro ACE Special</p>
Tartan 1.34 (pin), Twin .77 (pin)</p>
Tech 23CC (pin)</p>
Technipower 7 Cylinder radial, B series, 9 cylinder</p>
3MM 53 TOC (pin)</p>
3W 26 CC (pin), 80 CC Boxer Twin (pin)</p>
Thunder Tiger .39 (pin), Pro .50 H (pin), .53 Red Line Heli (pin), .54 4C, .91 FS 4C, 120 Pro (pin)</p>
Toki .40 (pin)</p>
Ueda .45, .61</p>
US 25 CC (pin)</p>
Vlvatam 2.5, 5 CC</p>
Veco .21 Dykes, .50 Dykes, .61, .61 Dykes</p>
Vega 10CC, 91 4/C</p>
Webra .32 Speed Dykes (pin), 35 (pin), 10 ccm, 6.5 (pin), .40, .40 (pin), .40 Dykes (pin), .50 Dykes (pin), 52 (pin), .55C AAR Red Head Heli (pin), .61, .61 (pin), Speed .61 FS (pin), Speed .61 F Dykes (pin), .61 Dykes (pin), Speed 70 (pin), T480 4C Dykes, .91 (pin), 91 PS (pin), 120 Dykes (pin), 1.2 LS (pin), 91 (pin) T 4.90, 35 CC? Bully (pin)</p>
Weedeater 18 CC (pin), 21CC (pin), 25CC (pin) 1.358 Bore, 25CC (pin) 1.380 Bore, 28 CC (pin), 32CC (pin)</p>
Weedwacker 25CC (pin)</p>
Westbury Atom III</p>
Yamaha 50CC (pin)</p>
YS .50 ST,.61 Long Stroke (pin), .63 4/C, .80 H (pin) 2C, F.91 AC 4C, .91 2C (pin), 110 4/C, F120 4C</p>
YW 24CC single &amp; 48CC Twin (pin)</p>
ZDZ 40 (pin), 50 NG RV (pin), 60 RV (pin), early 80 RV (pin), later 80 - J model (pin)</p>
ZEN G270 (pin) AKA Chung Yang</p>
Zenoah G20 (Pin), G23 (pin), G26 (pin), G38 (pin), G45 (pin), G62 (pin), GT-80 Twin (pin)
</p>
av8tor1977 07-05-2011 09:24 PM
RE: Frank Bowman Piston Rings
I just ordered rings for 5 different engines from him. He e-mailed me back instantly. Great service, great rings. (I've been using them for years.)
AV8TOR
captinjohn 07-11-2011 05:22 PM
av8tor, Have you seen the video of that nice 3cylinder engine in the mustang. I am trying to find all the 4 cycle small power products like the Husky 4 stroke engine...so as to join 3 the same to make a 3 cylinder engine that fires every 120 degrees apart. It seems possible to come up witha nice sounding engine....something that at least sounds like the engine in the Galloping Gost Video. In short....got any Ideas? Thanks Capt,n P.S A top class machinest wants to build it too. http://www.rcuniverse.com/forum/js/f.../thumbs_up.gif
w8ye 07-11-2011 05:31 PM
ORIGINAL: captinjohn
Notice that this engine had to have three individual ignition systems
av8tor1977 07-11-2011 06:25 PM
How about three of the Stihl "Four Mix" four stroke engines? No oil tank to worry about. They come in a series of 30cc engines, and a 65cc.
AV8TOR
SrTelemaster150 02-16-2013 10:23 AM
ORIGINAL: w8ye
av8tor, Have you seen the video of that nice 3cylinder engine in the mustang. I am trying to find all the 4 cycle small power products like the Husky 4 stroke engine...so as to join 3 the same to make a 3 cylinder engine that fires every 120 degrees apart. It seems possible to come up witha nice sounding engine....something that at least sounds like the engine in the Galloping Gost Video. In short....got any Ideas? Thanks Capt,n P.S A top class machinest wants to build it too. [img][/img]
Since the single magnet/sensor C&H CDI for the 3 cylinder radials fires every 120°, it would be a perfect match for a 3 cylinder inline.
