rare 50 cc engine
1 Attachment(s)
This is a rare engine to convert to electronic ignition. In fact it has an electronic ignition using a zenoah coil, some electronics, battery connection, and mechanical avance conected to throtle
will start making all necessary parts and disassembling all engine for service |
RE: rare 50 cc engine
That looks like it might be an Echo engine from a chainsaw. If so, it should be a good engine. The manner in which it is converted and the type of electronic ignition makes me think it was converted by Ralph Cunningham, known here in the forum as "Antique". If that is true, the ignition system is a VERY good one.
AV8TOR |
Perhaps cut out of an Echo CS-510. It looks like the two I converted.
It a RC Ignition conversion OK.
But the Echo 510 is a clamshell crankcase design? Would look like a BME Classic 50? |
1 Attachment(s)
CS-510-evl ???
That's what I think it is; the EVL.
AV8TOR |
Sachs Dolmar,3.2,orange case,if it is one ring it is a model 115,chain saw.I have one.What was the name of the engine company that used sachs engines.They went out of buisness years ago.
The engine size was a 52cc.I have 2 of them i can not remember the name.They where kinda known for there crankshaft problems. That is why we put different cranks in them.they where silver machined case.But looks like a Ralph conversion for sure. |
It is :D
