RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   mcculloch 32cc timing ? (https://www.rcuniverse.com/forum/engine-conversions-92/10832212-mcculloch-32cc-timing.html)
the wylie coyote 11-27-2011 08:04 PM
Does anyone know were i could find the timing degree setting for a mcculloch eager beaver 32 bcs weed wacker?</p>
tkg 11-27-2011 08:40 PM
RE: mcculloch 32cc timing ?
Battery ignition or magneto ignition???
spaceworm 11-28-2011 07:29 AM
ORIGINAL: tkg
Does the ignition spark point depend on what type of spark initiation? I am curious as I have thought the position of the piston at spark to be independent of type of ignition system. Thank you, I sincerely am looking for your answer to the original question.
Sincerely, Richard
tkg 11-28-2011 09:22 AM
If the engine has electronic ignition then you CAN adjust the timing, ideal would be 30deg BTDC. If its on the magneto then the timing is fixed at around 24 deg BTDC. If you could make an adjustable timing bracket for the coil then you would also set it for 30 deg.
dogshome 11-28-2011 11:44 AM
If electronic advance, you could probably go as far as 40 degree at full advance. They are very low compression.
Fixed Mag ignition is a compromise between easy starting and max power.
w8ye 11-28-2011 01:47 PM
Back in the late 90's I put together two of these with some of the parts from TKG. They had CH battery ignitions.
I played with the timing at different settings on the first one. There was not a significant difference in maximum RPM between 24 degrees and 32 degrees. I eventually set it at 28 degrees. The second one I just set the timing at 28 degrees and left it there.
Jezmo 11-28-2011 03:05 PM
As Jim has, I've moved my timing around on everything from my converted SuperTigre 51 all the way up to my DLE55 and found NO gain in rpm's after 30 degrees and sometimes it even falls off before I get to 36. The 50cc stuff starts kicking back a lot when you get up around 40. I set all mine at 28-30 now. I've done the research for myself and see no need for any more. (with the exception of my four stroke conversions which are a completely different animal altogether.)
dogshome 11-29-2011 01:14 PM
The SPE 26 and the McCulloch 32 I have are extremely low compression with small ports. 40 degrees just starts to kickback. 28 degrees loses several hundred RPM the top end.
Any sort of chainsaw derivative / DL / fourstroke glow conversion / twostroke glow conversion would bite your hand off at 40 degrees - I agree!
Bike four strokes typically advance to 40 degrees.
the wylie coyote 12-03-2011 06:03 AM
the mcculloch 32cc right now still has its stock magneto but i want to shave some weight off and go with electronic ingnition. So is 28 degrees a good starting point? Then play with it from there.
rangerfredbob 12-03-2011 07:50 AM
I'd just leave it there, I'm running that exact engine that massaged the exhaust port to 150 degrees duration and set the timing at around 30 degrees and called it good, it runs like a top.
w8ye 12-03-2011 09:22 AM
Just put the ignition timing on 28-30 degrees BTDC like Ranger says and you will not do better than that. I've played around with them and that is the sweet spot.
