prop hub for cy engine
hello, does anyone know where I can get a prop hub for the tapered shaft of a cy engine.
I want to keep the pu ll start for use on an airboat .. Thanks !!! <br type="_moz" /> |
RE: prop hub for cy engine
Wacker Engines would be a start http://wackerengines.com/
They make prop hubs for many of the common utlility engines people get. This sticky thread at the beginning of this forum here also has more links to get out too. |
ORIGINAL: earlwb Wacker Engines would be a start http://wackerengines.com/ They make prop hubs for many of the common utlility engines people get. This sticky thread at the beginning of this forum here also has more links to get out too. I know there are guys on the forum that will make parts... It's a matter of finding someone to do it. I'll need a hub at some point myself for a Homelite 30cc. |
I think I would need to see pics of this particular engine and what that shaft looks like to tell for sure.
I told him to try www.lambertsrc.com as well. The only reason it would fly off would be if it is left hand thread, but there are ways around that too.
AV8TOR |
Checkout the hub from the SPE 26 engine. From memory it has a tapered shaft. Not sure if it will fit though.
Thanks guys for all the input !! I think I have a lead !! .....lol
I can make it...the thing is, id need to know some basic info such as the thread size( i.e. 8mm x 1.25) how long you want the prop hub to be and the crank taper. Geez, it might be easier just to send me the motor...;)
| All times are GMT -8. The time now is 11:44 PM. |
