RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   OS 91FS gas conversion? (https://www.rcuniverse.com/forum/engine-conversions-92/11585889-os-91fs-gas-conversion.html)
ameyam 08-29-2013 04:41 AM
Hi,
can a fs91 be converted to gas? If so, what kind of power can I expect? Is there a pumped carb for it?
Ameyam
dogshome 09-02-2013 12:10 PM
Hi, yes, but Walbro/Zama carbs are physically quite large. You can make an adaptor easily, see thread 180FS glow to gas conversion on this board.
A 20/64" or 24/64" should be the right size. Power will be less than glow, take 1" from the diameter you are using for glow. Guessing 14*6 or 13*8 about right size on gas.
P.S. I was in India (Chennai) last year, I hope i get the chance to visit Mumbai :cool:
bogbeagle 09-02-2013 12:38 PM
Yes, as stated, a "proper" carb will be needed if you want a good result.
You should also find that the glow plug will provide ignition, without the complexity of a separate spark-ignition system .... well, my little OS runs on petrol, just like a normal glow engine runs on glow fuel. I expect that your .90 will work just as well.
bklambdin 10-06-2013 04:55 PM
So your saying that you don't need a spark plug and timing to get the thing running right? I thought the power came from running a bit on the retard side because of pre-detonation of the gas... Please elaborate more on this setup Bob.
bogbeagle 10-06-2013 09:29 PM
Took my OS .30 two-stroke and ran it on a 10% petroil mix. Engine ran pretty well; started easily ... but the carby adjustment was hyper-critical.
So, the glow plug functioned in the same way that it does with methanol ... ie, as a catalyst.
Nothing more to tell you, 'cos that's the extent of my experimentation.
irocbsa 10-09-2013 07:51 AM
10% gas is not a big deal. There's a big thread on this forum about the gas/glow mix and the percentages that you can run while still continuing to use a glow plug. Link:
http://www.rcuniverse.com/forum/engi...-glow-how.html
You will not be able to use a glow plug if you run 100% gasoline unless you use a glow plug driver that is set to be on all the time. At that point, why not just do it the right way and use a CDI system?
bogbeagle 10-09-2013 08:56 AM
No, that's 10% oil, 90% petrol.
And it does work, without a glow driver.
irocbsa 10-10-2013 07:13 AM
That seems impossible, but apparently it isn't. I would think that it would be detonating all over the place. What type of plug? Are you using a gas (Walbro type) carb?
bogbeagle 10-10-2013 07:41 AM
Ordinary glow plug.
Standard OS carb.
Carb adjustment very critical ... almost impossible to get it right. But, the engine does run and sustain itself. Can't say that I noticed detonation, but I spent about 20 mins with my mouth agape.
There's a thread somewhere, about a commercial version of this ... .40-sized two-stroke, running on petroil mix and glow plug. Buuuuut, that engine has a carb which is made for the job, with appropriately-fine metering.
irocbsa 10-10-2013 08:04 AM
Well, congrats on a very cool project.
I think the engine you're referring to is a Norvel 40. Apparently is has a specially coated liner (and maybe piston too) and you have to run a ton of oil but a few guys are reporting pretty good results.
ameyam 10-11-2013 12:24 AM
Hi,
my engine needs a new head because the head muffler connection threads have slipped. Plus I need head screws. OS went for an odd size of 3.5mm for these engines and these arent available locally. I will need to get those from OS as well. With a FS72a, a FS91 running and another FS91SII, FS110A, 65ax, 95ax and 120ax sitting in the box (those are just the glow engines I have:o), there was no point trying to restore this one. Thats why the gas conversion question. But with a blown head and no easy way to convert to gas, there is not much point in the gas conversion either.
By the way, the engine has a neoprene seal o-ring in the carb and the HSN. Wont those need to be replaced if I run gas in it?
Ameyam
bogbeagle 10-11-2013 12:33 AM
Well, if the glow plug' threads are ruined, you could close off the hole and try the engine on model diesel fuel.
It might surprise you.
My Enya .60 four-stroke runs on diesel, without any modifications. To be fair the CR is a tad low and a Cetane additive helps with reliability. The CR on your OS might be higher than 8:1 ... which is the CR on my Enya.
Anyway, you don't have much to lose by giving it a try.
ameyam 10-11-2013 05:16 AM
No, threads for the silencer are spoilt
Ameyam
bogbeagle 10-11-2013 06:09 AM
OK, so run the engine without a silencer.
You should be able to fabricate a short stub-pipe, which attaches to the head ... it may be that you can cut a completely different thread to that which exists; a Metric Coarse thread might do the trick. Once you have a short stub, permanently-fitted, you can lead away the exhaust goo.
It all depends upon what facilities you have.
I run several engines on straight pipes and I find the sound quite acceptable.
