RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   Walbro carburettor sizes. (https://www.rcuniverse.com/forum/engine-conversions-92/11656687-walbro-carburettor-sizes.html)
Jim.Thompson 11-15-2018 05:05 AM
In several of the engine conversion threads, Walbro carburettors are identified by the size of the venturi.
One size that I am interested in is 12.7 mm.
Can someone tell me what model Walbro carbs are this size please?
Tidnab 11-16-2018 04:43 AM
Here you go Jim.Just click on each letter group and then to each carb.
Select the Series [Frontstep Customer Center 5 Frontstep, Inc.]
By looking at Gizmomotors site the WT 257,WT 1048 and the WT 771 must be the best carbs for an engine. https://www.gizmomotors.com/index.php/online-store
speedracerntrixie 11-16-2018 08:49 AM
Jim, I take the easy/lazy way. I simply order a replacement carb for a like displacement engine from an R/C engine vendor. Example, a couple of months ago I bought an airplane with a 3W 70 twin. Even after rebuilding the original Tillotson carb I still could not get it to work correctly. I ordered up a DA 70 twin Walbro replacement directly from DA. Works like a charm and since I ordered it from DA I know I got a genuine Walbro carb and not a knock off.
Tidnab 11-16-2018 11:18 AM
What was the Walbro number on that DA 70 twin carb ?
Jim.Thompson 11-16-2018 12:40 PM
Thanks for that Tidnab!
Jim, I take the easy/lazy way. I simply order a replacement carb for a like displacement engine from an R/C engine vendor.........................
Yes. I found a similar correlation which confirmed my choice of model carb for the OPS engine I have.
Thanks for the reply.
