husqvarna help
I have a husqvana model # 28HBV blower. does anyone know of a web site that would give the size engine it is. no writing on motor. looks like it would make a great conversion project. also anyone who sales conversion parts for it. thanks harold
RE: husqvarna help
I have had several Husqvarna line trimmers etc, and the size was relevant to it's code eg: R25 line trimmer was 25cc...
Not sure if it still is though... Regards cmsrp |
RE: husqvarna help
cmsrp is correct it is a 28cc should swing a 18x8 - 18x10 prop no problem.
Darin |
RE: husqvarna help
ryobi longshaft conversion parts should fit it. I have a freind that has one. Im trying to talk him it converting it. The ryobi flywheel is also the same as the huskys too. www.wackerengines.com has all the parts you need but double check to make sure im right, I cant see you motor im just going by the one i've seen.
| All times are GMT -8. The time now is 05:44 AM. |
