Ignition Coil
I just ordered a TIM 6 from JEH. Are there any other coils that can be used with this ignition? I read in some of the threads that the modelectric coil is not very good.
RE: Ignition Coil
The Modelectric coil will be OK with this circuit, the insulation is not very good when used with a CD electronic igniton circuit, which puts way more voltage through it....
RE: Ignition Coil
[link]http://www.gettig.com/coils.html[/link] has a nice little coil for kettering ignition.
dave |
RE: Ignition Coil
Will the coil offered by CH work withit? They have a grey coil that the wire screws on and a black one with a potted in wire.
RE: Ignition Coil
TKG knows...www.ch-ignitions.com
RE: Ignition Coil
[:o] Sorry CH Coil is for CDI only. If used with points it draws about 4 amps[:'(]
| All times are GMT -8. The time now is 12:41 AM. |
