RYOBI 31 CC - Am I Missing KEYWAY?
1 Attachment(s)
Have you come across this during your conversion of a Ryobi short shaft weedwacker motor for R/C aircraft use? While I was carefully removing the flywheel from a new RYOBI Weedwacker engine this is what I ended up with, see attached photo.
Nothing else was in there, I searched the floor, bench top and also the flywheel's magnet! Please clue me in, am I missing a piece of the keyway? Embossed on the flywheel's front face is <Wabro G 58> Thanks in advance, Rejean |
RE: RYOBI 31 CC - Am I Missing KEYWAY?
the "key" is cast as part of the flywheel, most of the newer engines are done this way.
dave |
Zagnut is right on about this and you have the good ign. (walbro) it is a hotter spark than the phelon.
Darin |
Yup- it's cast into the flywheel. I've got 3 of these flywheels-- all long shafts.
I don't use them. I put electronic ignition on all my conversions. Anyone want to buy some flywheels and coils cheap? |
Thanks for the quick response guys, now I will sleep better tonight knowing that I am not missing anything.
I bought mine today from Liquidation World; they had them on for $99 Canadian ($75 US). Model ZR765R Thanks again folks, Rejean |
Hi Rejean
This may help you to be sure to have all the engine's part. Regards http://www.ryobi-europe.com/DOC/E746.PDF |
| All times are GMT -8. The time now is 12:02 PM. |
