RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   inverted with vent opened (https://www.rcuniverse.com/forum/engine-conversions-92/1413307-inverted-vent-opened.html)
Ronnies 01-08-2004 06:17 PM
I f I hook up my tank fuel , so the vent line is just opened , and I fly inverted will the fuel spill out with a 25cc echo converstion
MILDBILL-RCU 01-08-2004 07:48 PM
RE: inverted with vent opened
Just run the vent line down below the bottom edge of the tank, & when inverted, it will be above the level of fuel in the tank & wont leak the fuel out. .........mildbill
mdavies31 01-08-2004 10:21 PM
I routed the vent line down below the tank then to the rear, up and around the back to the top and above the tank to the front then down again and out of the fuselage about 2 inches.
Looking from the side the line makes a oval around the the tank, that way no matter what attitude the plane is in some part on the vent line is always higher than the tank.
Ronnies 01-08-2004 10:48 PM
mdavies31 RE: inverted with vent opened (in reply to MILDBILL-RCU) Report This Post | (Post No. 3)
can you send me a picture of the tank routing thanks ronnie [email protected]
mdavies31 01-09-2004 02:32 PM
I can send the picture tomorrow, stuck at work today.
Ronnies 01-10-2004 03:30 AM
1 Attachment(s)
Thanks guys it makes sense nowHI Ron-
[img][/img]
airbr 01-11-2004 12:50 AM
hey guys all you need to do is use a check valve and and turn it so that if you blow in it you would blow air in the tank but nothing will come back out. Your carb has a reg pump so things will work just fine.
