Poulan
Poulan 60, converted, 24-8 old Zinger, 6400 rpm..22-10 Zinger, 7200 rpm..
20-5 PK, 8800 rpm Weight 4 lbs 4 oz WITH ignition inside the mount. |
RE: Poulan
these engines love the 22x8 pk plus props lots of power i do make a wrap around muffler for these engines $85.00 shipped
RE: Poulan
The Menz 22-8 turned around 7200, will try again tomorrow with a few more props..
the stock chainsaw muffler is quiet but really cuts down on the rpm... that 20-5 PK test was just for kicks, a 20 inch prop is way small for this engine.. A sticker on the handle says max rpm is 13,800... |
RE: Poulan
HI RCIGN have been trying to hookup with you for an address to send remitance for bluelight special please contact at balsadust_2 @ joplin.com I think or through the forum thanks Les
RE: Poulan
Hello all
Thanks for the info RCIGN. Can we also get some thrust #'s with the prop's? thanks, Randy |
RE: Poulan
I have no way to test thrust unless the engine is on an airplane..The owner is coming by tomorrow to take it home, so maybe when he gets it on a plane he'll put some numbers on here...
A good G62 turns the same prop about 6200....The numbers will vary, it's cold and 6800 feet altitude here... |
| All times are GMT -8. The time now is 05:02 PM. |
