RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   McCulloch 32 conversion question (https://www.rcuniverse.com/forum/engine-conversions-92/1747125-mcculloch-32-conversion-question.html)
Pilotsmoe 04-22-2004 02:28 AM
1 Attachment(s)
I am trying to convert the McCulloch 32 engine, but I cant seem to figure how to get the clutch off[>:][:@]. Any ideas?
Willdo 04-22-2004 03:44 AM
RE: McCulloch 32 conversion question
From memory, it has an allen head screw down the centre of the clutch, you'll probably have to grip the flywheel between 2 pieces of wood in a vice.
Hope this helps.
rcrobby82 01-22-2005 05:16 PM
wierd, i just got the same engine it looks like. mine was off of a pro mac III weed whacker. i had the same issue. there is a bolt in the center of the shaft, heres the catch. the shaft that the clutch is on is not the crank shaft. rather it is a extension piece threaded onto the crank. find a way to hold the flywheel and turn the clutch assembely. or you could do what i did. i got pi$$ed off and drilled the bolt head off the clutch which made everything real easy to get apart and did not damage any important parts. it looks in the pic like you got as mad as me. :) i would have just unscrewed the bolt but mine was all rounded out so that was not an option. hope this helps.
tkg 01-22-2005 11:17 PM
Take some small rope and stuff it in the spark plug hole. When you try to losen the bolt the crank will turn and jam the rope with the piston and stop turning. Then you can losen the allen bolt. NOTE some of the bolts are a #25 Torque and not an Allen.
