RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   Conversion Hardware (https://www.rcuniverse.com/forum/engine-conversions-92/1896196-conversion-hardware.html)
navpro 06-12-2004 12:16 PM
Conversion Hardware
Hello!!! I was wondering if someone could tell me where I can get the hardware needed to convert a weedeater engine to R/C use (prop hub, etc.)??? Also, what is the rule-of-thumb for the distance between the engine and the receiver to avoid radio interference??? Thanks in advance...
teufelhund 06-12-2004 06:20 PM
RE: Conversion Hardware
Hi navpro,
If you do asearch on this site you will turn up quite a few; www.wackerengines.com - www.carrprecision.com - www.rcignitions.com - http://bennettbuilt.com/ - and others I'm sure I haven't listed them all. The concensus seems to be at least 12-15 inches from engine and electronic igniton if equipped and if CG allows. Good luck! Ben
navpro 06-12-2004 10:59 PM
Thanks for the info....
glowplugboy 06-14-2004 10:48 PM
[link=http://www.gcbmrc.com]GCBM R/C Models Inc.[/link] is also a great source for quality conversion parts, and they are in Texas.
