RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   Mac 35cc (https://www.rcuniverse.com/forum/engine-conversions-92/1965065-mac-35cc.html)
Rambo-RCU 07-06-2004 11:36 AM
Mac 35cc
Has anyone done anything with the Maccoulough 35cc chain saw engine? I have 2 and would like to know specifics such as power it puts out and what type mounting, etc.Thanks
Rcpilot 07-06-2004 12:35 PM
RE: Mac 35cc
I've got one of them sitting around here somewhere.
Problem I ran into is the needle bearings on the crank. You can make a thrust washer from bronze, and install between the crank and bearings.
You can also have the case machined on the prop hub side and install a regular roller bearing on that side. No need to bother with the back bearings.
Lot of work for a 35cc engine. Personally, since I don't have the mills and lathes for makeing my own parts; I don't bother with anythihng that I can have done for a reasonable cost $$$ by someone else. IMO, making bronze thrust washers or milling the stock case to accept a roller bearing- is too costly for the intended purpose. IMO- the whole point to a conversion is that it's cheaper than a DA or ZDZ. Spending a bunch of money on machine work is not the idea behind the conversion engines.
Craftsman makes a 38cc engine that practically converts itself. A Ryobi 31cc engine can be converted in about 1 HR- once you've gathered all the parts.
