RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   1/4 Scale Kitten? (https://www.rcuniverse.com/forum/engine-conversions-92/1997803-1-4-scale-kitten.html)
Sky Viper 07-16-2004 08:45 PM
1/4 Scale Kitten?
I have plans for a 1/4 Scale Kitten designed by Emil Agosta.
It has a 90" wing and 1080 sq. in. area.
The plans claim a weight of 7.5 Lbs. and recomends a .40 2c glow.
Anyone have one of these birdies?
I was hoping to put my first Ryobi on a nice leisurely high wing like a kitten, but according to those specs, I'd have to enlarge the plans by what, 30% or more?
That would be nearly a 10 ft. wing! [X(]
I don't have a problem re-engineering to that size, but my goodness, what a space hog that will be in my shed(mini-barn) and on the flight line.
So, the real question for you "Experienced" folks is this: would the Ryobi be a good fit with a 30% enlargement? How about 25%?
Tom
Sportflier 07-16-2004 09:52 PM
RE: 1/4 Scale Kitten?
I don't think you need to go to 30% or even 25% enlargement. 20% will give you an 8 Ft, wing and 1555 sq. in. area, and if you can keep the weight down to 12 or 14 lbs or so, it will float like a butterfly. Just doing the cube function on the 20% increase on 7.5 lbs gives 13 pounds. and the Ryobi weighs about 4 pounds in itself so a 12 to 14 pound target seems reasonable. When you scale up the plans go for pine or spruce spars with shear webs, good strong struts, braced tail surfaces and stout landing gear.
My 1/4 scale Cub is very close to the size of your 20% enlargement, and flies fine with a 28cc Ryobi that turns a 18X6 at 7000 rpm max on a good day. And the Cub weighs 17 pounds!
Allan
Sportflier 07-16-2004 10:15 PM
Ooops, 20% enlargement gives 108" span, which is 9', not the 8' typo as per my previous post. Area is still 1555 sq in and the rest is OK (?!).
