RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   Homelite 30cc throttle linkage problem (https://www.rcuniverse.com/forum/engine-conversions-92/2118994-homelite-30cc-throttle-linkage-problem.html)
deu 08-25-2004 08:42 PM
1 Attachment(s)
Ran into a problem hooking up the throttle linkage on a Homelite 30CC engine. I believe the engine came from a Weedeater and the linkage operates up and down and not back and forward.
The pictures are with the plane on its side.
w8ye 08-26-2004 02:00 AM
RE: Homelite 30cc throttle linkage problem
The engine does not appear to be a weed eater type Homlite.
On my '30', I mounted a 90 degree bellcrank under the carb to change the direction. I had a short ball link set up between the carb and the bellcrank.
Enjoy,
Jim
av8tor1977 08-26-2004 09:53 AM
1 Attachment(s)
Here you go:
See pic.
AV8TOR
