What diameter prop should a Echo 40 handle?
I'm in the process of converting one of the older Echo 40s that had points type ign in rear. Out of a back-pack blower. This is my largest cc convert to-date and have no idea of what diameter prop would be best match.
I have some 2" Alum bar stock to make the prop hub. What I would like to know is what diameter face should I plan on? I have MAS and APC 18" props so that diameter is not a problem, but it a Echo 40 cc , 3 ring piston. 7/16" diameter output shaft will swing a larger diameter, I need some guidelines for surface diameter contacting the rear of prop. Thanks |
RE: What diameter prop should a Echo 40 handle?
2 inches is large enough for my 289cc race engine, it should be enough for a 40cc Echo :D 1 1/2 is plenty....Anything bigger than the width of the prop is just wasted aluminum....
I have a 3/8-24 center bolt and two 1/4-20 bolts on a 1 1/2" bolt circle through the prop...[8D] |
Hi RCIGN
nice numbers, I am converting a 70 cc chainsaw engine (italian ALPINA)and think about the right diameter of prop adapter. What a feeling tuning that beast. I will pay for a tuning session. Many thanks for your example. |
most of the 3W singles use a 40mm hub. find pics of these engines with various props and see if it suits you.
dave |
Just didn't want to error in making the diameter too small! May have just searched in wrong places and the pics scale objects, they all look about the same.
FWIW:1) Our 18" is 1-5/8" and our 20" is 1-3/4". Hope that helps. Thanks Mike Clemmens MSC Propshttp://www.mscprops.com Eiit added: 3) From Windsor Props: For the 20" props the measurement is 1.75" and 1.80"/ Sincerely, Fred Jamieson Windsor PRopeller Company |
| All times are GMT -8. The time now is 06:39 AM. |
