RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   Walbro 167A diaphram vent problem (https://www.rcuniverse.com/forum/engine-conversions-92/2459928-walbro-167a-diaphram-vent-problem.html)
mikenlapaz 12-22-2004 09:02 PM
This carb has the primer bulb and the diapharm vent is in the plastic housing, partially covered by the bulb retainer plate.
Engine, Echo 21cc, ran fine on stand but I ended up making a longer throttle arm and installing it upside down (needle down). Engine now runs like cr@#. (starts fine but will not power up). Put my hand behind carb while running and got big RPM improvement. Figured a velocity stack, homemade, would help and it made it worse. No throttle response.
Stack mod A was pointing aft; mod B got 45 degree cut to where throttle plate was visible. Mod B got the throttle response back but still low RPM.
After thread searching, I think the problem is prop wash directly on the diaphram vent hole. (Open to other ideas)
I do not have any metal diaphram cover plates to modify. (On-hand Zama are all wrong) Any suggestions on method of attaching a vent line into this plastic?
Pics to follow...dinner
mikenlapaz 12-24-2004 12:40 AM
RE: Walbro 167A diaphram vent problem
Most comments on using velocity stacks advise to place major opening side aft.
What is the reasoning? If the diaphram vent is aft I understand, both would be somewhat blocked from prop wash (non-cowled opening). If 'vent' is forward what problem(s) should I expect if I rotate the velocity stack to face forward where both intake and vent encounter same prop wash?
I rotated velocity stack (now faces forward) and got somewhat improved RPM, have not finished carb adjust yet.
