RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   Stihl weedwacker conversion. (https://www.rcuniverse.com/forum/engine-conversions-92/2651729-stihl-weedwacker-conversion.html)
fwman1 02-12-2005 11:12 PM
1 Attachment(s)
Going to give this one a whirl. Not sure about the CC, but it's a twin ring with good compression. Carb was missing so I'll have to use one I've got sitting around. Pretty light with a built-in mount. If it works out, I'll use it on a BUSA Eindecker. A .91 four-stroke will fly one well, so I should have enough power with this engine. The design requires much nose weight any way. I left both these 'ears' on so I could decide later where to place the ignition pickup.
captinjohn 02-13-2005 12:01 AM
RE: Stihl weedwacker conversion.
If it does not have the power you want on gas...strip it down as light as possible and put a Glow plug adapter in it and run Glow fuel. Just a thought!!!
