Cheap Homemade Muffler
1 Attachment(s)
I know this has been done a lot, but I thought this works well, is easy, and cheap
(This was inspired by efforts by mikenlapaz) Weight is 5 oz. $10 buys enough aluminum to do 4 mufflers Simple to build, with hand tools only A little louder than stock ryobi muffler, but no worse than a typical chainsaw Turns 7000 rpm on MA Classic 18x8 (single ring ryobi, circa 95) (Have not directly compared to stock muffler, which will not fit on my motor mount) I will post details if anyone is interested Pete Johnson |
RE: Cheap Homemade Muffler
Well that's pretty neat. Nice job. I may have to try that.
AV8TOR |
More comments after actually down loading the pics.
At first I thought the "tubing" in the middle was actually that; tubing for compressive purposes, and I wondered why it did not go all the way from vertical stack to vertical stack. But after studying it for a moment I realized they were probably just threaded connectors... right? Also, why not carefully spread some JB Weld at the junctions to prevent leakage? Very nice looking, AV8TOR |
Yes, those are just threaded aluminum couplers I planned on closing up the gaps with JB weld and maybe pop riviting the corners but this works fine, doesn't leak noticeably, and can be disassembled if need be The flat head bolts seat against the hole Pete Johnson |
The bolts that hold the muffler to the engine will squeeze the aluminum together and the muffler will get lose. Cut some aluminum tubing the right length to fit over the screw part inside the muffler so the bolt heads will have something solid to snug up to.
Enjoy, Jim |
If you mean the bolts that thread into the holes next to the exhaust port
I already did that, if you look close in the center picture, you'll see 'em Pete |
Very good idea, It will work for a poor man like myself whom is in love with the hobby.
Sorry about not being able to tell for sure about the internal support tubes. At least we got the point across that this needs to be done? Good job.
Enjoy, Jim |
Very good idea & good job!
What is the square tube under the exhaust port square tube work for? Is the 2 square tubes internal connected? Could you post detail construction? Thanks for sharing the good idea JP |
1 Attachment(s)
The tubes are 1" and 3/4" square 1/16" walled aluminum tubing, 4" long
The two 3/4" tubes are side by side with 1/2" holes (two of them) connecting them This was done to increase the chamber size of the muffler as well as make the assembly more rigid The 1" side tubes have 3/4" x 1 1/2" square holes in the side to accept the 3/4" tubes These were done by drilling a series of 1/4" holes to remove the bulk of material and then enlarging the hole with a coarse file The fit of these holes is very tight The 1/16" gap between the tubes (inside the side tubes) is filled with 1/16" fiber gasket material This is shown in gray in the diagram These are inserted from the end of the side tubes, prior to assembly The whole thing is held together with long bolts and locktite Not shown in the diagram but mentioned in the previous post is the 5/8" x 1/4" hollow spacers around the mounting bolts which support the muffler when you tighten the bolts that hold the muffler to the engine. I hope this is clear Pete |
pcjohnson_ohio
Mikey Likes It! A definite improvement in square tube exhaust deflectors. My experience with JB on mufflers is a limited but I think I will try some red RTV sealant between the two 'chamber pieces" Nice Job and drawing. |
Pete,
Great information, excellent worK! Thanks for sharing your work with the rest of us. Gary |
Thanks to all
I tried to find Mike's old post, never did Call me cheap but there is something appealing about a $5 muffler that works and looks good (I think it does anyway) Pete |
| All times are GMT -8. The time now is 01:41 AM. |
