RE: Poulan 25 from FL trimmer
ORIGINAL: diablo_r I've heard about the alu welding stuff, you can buy it here but I've heard that with an engine runnign in a cowl it can get hot enough to remelt the magic stuff and the pipe falls to bits. I don't think these pipes will get hotter than 300 - 400F. Aluminum is good conductor so the heat is distributed through the entire muffler and the surface is cooled quite efficient. I read somewhere that the rod is good up to 700F so if it flexes and expands together with aluminum it should be OK. The entire load is carried through the thread anyway, I just need something to keep the pipes from unscrewing in vibration. RysiuM |
Hi Rysium,
I've sorted mine with 35% glow fuel, 65% methanol and spent last weekend flying it. It ran great but really needs a 17 or 18x6 on my Pitts for a bit more thrust. Vertical is not bad, but not unlimited. I did the full aero routine with it and the engine ran faultlessly so I'm pleased with that. Only thing is I did the psiton side cutouts under the gudgeon pin and it lost 300 revs. I'm going to put a std pitson back in sometime and try it but I'd leave that mod if you've not already done it as I don't think its a wise one. Also got the wacker engines muffler today so thats fitted, another 8oz off the engine. Total weight of the glow version is 920g now. Next job is I'm developing two electronic ignitions for it, one fixed timing and one variable. Should have the fixed one running by weekend and a few weeks for the variable one. Just as a side note when I got the muffler it had a note in saying if you send it back they will weld the pipes into the muffler for free, you jsut pay the postage. I have drilled and lockwired mine, and the mounting bolts, to stop them coming undone. Let me know how you are getting on. I got another 2 engines the same too so will get into tuning them soon. Cheers, Rich |
Hi Rich,
ORIGINAL: diablo_r I've sorted mine with 35% glow fuel, 65% methanol and spent last weekend flying it. ORIGINAL: diablo_r It ran great but really needs a 17 or 18x6 on my Pitts for a bit more thrust. Vertical is not bad, but not unlimited. ORIGINAL: diablo_r Only thing is I did the psiton side cutouts under the gudgeon pin and it lost 300 revs. I'm going to put a std pitson back in sometime and try it but I'd leave that mod if you've not already done it as I don't think its a wise one. ORIGINAL: diablo_r Next job is I'm developing two electronic ignitions for it, one fixed timing and one variable. Should have the fixed one running by weekend and a few weeks for the variable one. ORIGINAL: diablo_r Just as a side note when I got the muffler it had a note in saying if you send it back they will weld the pipes into the muffler for free, you jsut pay the postage. I have drilled and lockwired mine, and the mounting bolts, to stop them coming undone. ORIGINAL: diablo_r Let me know how you are getting on. RysiuM |
opps, sorry to get you so excited, it was 35% glow, 65% petrol, my mind must have been somewhere else when I typed that! I've got 2 gallons of straight methanol on order though so will have that soon.
I have not run the muffler yet, maybe at the weekend I'll fly it again but lockwire should be fine until I save up for a TiG! Pitts is just under 12lbs, and on the 16x8 APC at 8600 it pulls 13lb thrust when I measured it, so a 17 or 18x6 should be 15-16lbs thrust I would guess. I'll get one ordered tomorrow probably ready for weekend. The other thing I did to my muffler was put a metal drift into the inlet hole and hit it with a hammer, mushrooming the top of the pipes thread to stop them coming out. A bit extreme but I don;t want them coming out[:-] Cheers, Rich |
ORIGINAL: diablo_r opps, sorry to get you so excited, it was 35% glow, 65% petrol, my mind must have been somewhere else when I typed that! I've got 2 gallons of straight methanol on order though so will have that soon. ORIGINAL: diablo_r I have not run the muffler yet, maybe at the weekend I'll fly it again but lockwire should be fine until I save up for a TiG! ORIGINAL: diablo_r Pitts is just under 12lbs, and on the 16x8 APC at 8600 it pulls 13lb thrust when I measured it, so a 17 or 18x6 should be 15-16lbs thrust I would guess. I'll get one ordered tomorrow probably ready for weekend. ORIGINAL: diablo_r The other thing I did to my muffler was put a metal drift into the inlet hole and hit it with a hammer, mushrooming the top of the pipes thread to stop them coming out. A bit extreme but I don;t want them coming out[:-] RysiuM |
So I guess it keeps running without power on glow, right? Cheers, Rich |
Hi
Many thanks for your tip , dave wallace in page 5, post 105 the piston skirt cover the transfer ports. I have flown my STOCK weedeater for more than 4 hours when have a spark plug problem. When check the plug I inspect visually the piston crown and see the path of fresh mixture from the transfers . The back transfer have a shiny path of fresh mixture ,the polished surface of the piston is like new and the front path (where the counterbalance of crankshaft is) do not exist, the same black coloration of the all other parts of the crown. I am running at 5% 2 stroke oil and extra gas. Venturi enlarged at 9.5 mm diameter It make me to take the piston and with a file modify the skirt like in the photo of your post 105 , at a depth of 5 mm.Your depth is bigger may be 1/4 inch, refered to the ring in inside piston wall I will make a test now. I resist the temptation of start the dremel and enlarge the transfer and ports to the next time. I am flying with stock air filter, have very much dust in "my airport"and have windy weather, a bit loss in performance but have no option. Many thanks for your time to post photos. Jose Argentina |
| All times are GMT -8. The time now is 07:09 AM. |
