RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   engine interference issolation (https://www.rcuniverse.com/forum/engine-conversions-92/3303270-engine-interference-issolation.html)
ETRNL 08-27-2005 12:15 AM
1 Attachment(s)
ok i know that most of the people here use the engines for planes, but how do you issolate the engine interference comming from the engine. all i get is constant glitching with the motor running. i have another set of elctronics that i am going to try, but if that dosen't solve the problem i need to figure this out. do i possible need to groung the electronics to the frame????
anyways my head hurts so i will let some else think of something to do..
PS it is coming together nicely:D
THNX ETRNL
davewallace 08-27-2005 12:52 AM
RE: engine interference issolation
Hello,
With airplanes it is recomended to keep the radio equipment 10-12 inches away from the engine ignition. Don't use any metal control rods or wiring between the engine and the radio. Keep the antenna away also. Use a resister spark plug gapped at between 20-25 thousands. I don't know how the car and boat people accomplish this, maybe they use sheilding of some sort. Try the car forum. Good luck.
Dave
ETRNL 08-27-2005 12:53 AM
the resistor spark plug... is that different than what comes with the engine???
davewallace 08-27-2005 01:29 AM
Yes. Champion have an R at the begining. NGK and others have a R in the id number such as BPMR6F. If you do a search of RCU on thease things, you would be suprized at what you will find.
Dave
gottagofaster 08-27-2005 07:49 AM
This has nothing to do with your problem, but thats a sweet truck. That's based off a T Maxx right?
On the resistor plug thing, take the # off teh current plug, and take it down to your small engines place, tell them you need that plug in a resistor version.
ETRNL 08-27-2005 11:25 AM
T Maxx correct!!!:D
and thnx for the replies
ernest2 09-02-2005 03:46 AM
do you know if what number for bosch spark plugs are resistor type which will be ok for a homelite 25cc?
