Side Port Ryobi? 30cc
I was looking at engines again. Home depot has a product with a Ryobi 30cc engine with carb on side of cyl....Not rear intake like many. It sure looks like a good conversion. Will check it out more. Capt,n ;)
RE: Side Port Ryobi? 30cc
This is the Homelite/Ryobi engine, made in China. The cylinder has excellent transfer ports but can use some help on the intake and exhaust. Properly modified, it should make serious power. I don't think parts will interchange with the early Homelite.
Today I got a new Homelite 30cc Yard Broom II for $80. This is the same engine as the Ryobi 30cc long shaft. I am in the process of matching the transfers to the crankcase and porting the cylinder. The intake manifold mounts the carb with the shaft vertical. This cylinder has a larger exhaust port but it is seriously reduced at the piston, it will require a lot of raising to get adequate exhaust timing. The intake port is very small. I will post results when they are avai8lable. The crank is different than the trimmer, there is a flat to drive the impeller and the length is different. |
Has anyone converted a side port 30cc Ryobi? Thanks Capt,n[:-]
I just finished cutting down the crankcase for CH ignition and matching the flange to the cylinder. I am going to port the cylinder but decided to test it stock first. There are some differences in the new Homelite/Ryobi 30cc and the old one. I have new Ryobi and Homelite 30cc engines as well as old Homelites. The new ones come with 10mm WYC carbs, 30% more cylinder finning, a heavier crankcase/cylinder flange, thin ring piston, crankcase reinforced between the flange and bearing, and VERY mild porting. The transfer ports are divided and huge. I replaced the blower crank with a long shaft trimmer crank so I could use the standard CH ignition and hub. Matching the cylinder to the crankcase requires cutting 1/4" square notches and extending the original transfer notch 1/8". This more than doubles the original transfer area. The stock crankcase has notches for the 25cc cylinder. This masks the bottom of the 30cc ports and makes most of the charge travel through the ports in the piston. This should be a much superior engine to the old Homelite 30cc, it will be interesting to see how it performs. I am still searching for a steel header pipe and probably will have to make one.
dbryan: That sounds great...keep us posted how it turns out. Capt,n
| All times are GMT -8. The time now is 09:56 PM. |
