RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   engine volume ? (https://www.rcuniverse.com/forum/engine-conversions-92/3747874-engine-volume.html)
coralcape 01-08-2006 02:57 PM
engine volume ?
Just finished converting a hedge clipper engine and would like to know the cyclinder volume. Any one know an easy method, like filling cyclinder with paint thinner and measuring same. If this will work, where should the piston be? Thanks, red
w8ye 01-08-2006 03:51 PM
RE: engine volume ?
You could get a good idea of the stroke with a dowel stuck down in the spark plug hole?
The Homelite hedge trimmer was 16.cc
The Weedeater brand were mostly 21's
Enjoy,
Jim
Rcpilot 01-08-2006 06:44 PM
RE: engine volume ?
Yup!
Stick a wooden dowel down the spark plug hole and measure the stroke.
Then take the muffler off and stick a piece of wood through the exhaust port when the piston is at the bottom. Measure the bore.
CC = stroke X area of the piston.
Area of a circle is 1/2 the diameter times itself. Then times 3.14127
Example:
2" stroke
2.5" bore
1/2 the diameter is 1.25"
1.25 x 1.25 = 1.5625
1.5625 x 3.14127 = 4.908234
4.908234 is the area of the piston in sq. inches
4.908234 x 2 (stroke) = 9.816
That would be 9.816 cubic inches.
:D
bn120 01-08-2006 08:47 PM
RE: engine volume ?
Here ya go
http://www.teamcalamari.com/dox/tekdisp.html
coralcape 01-09-2006 08:15 AM
RE: engine volume ?
Thank You all. Since I'm inherently lazy, I really liked the one from bn120. Thanks, red
av8tor1977 01-09-2006 10:53 AM
RE: engine volume ?
Slightly easier is:
((Bore x Bore) x stroke) x .7854) = displacement.
To get cc, divide your cubic inches by .061.
AV8TOR
