11mm carb for Ryobi 31
Apparently wacker engines has stopped carrying the larger bore 11mm Walboro carb for the Ryobi engines. Anyone out there know of a good inexpensive source in the US for these carbs ?
I am doing my first conversions, I have one carb with the 'California' single needle and the other has a fuel bleed for the choke which I dislike, so I'd like to change them out. In addition, I am looking for power similar to a G-26, these engines are going in 900 sq" single engine fighters. I've run G26's in this size plane and it works great, just looking to save some $$$. Mike |
RE: 11mm carb for Ryobi 31
w8ye,
It appears these guys specialize in G26 racing carbs, I'm not looking for something that special or pricey, hell the whole weedwacker was $50.00. I just need a larger 11mm carb, KatanaMM said the G-26 carb is 12mm and that it can be hard to get tuned properly. That I do wish to avoid. Peter at Wacker use to sell them $10.00 untested and $20.00 tested, that's more like it. Any other sources ? MT |
The first item, Walbro Wa 167 is the standard of comparison for 11 mm carbs for use on weed whackers. I have several of them.
$35 is a lot better price than going to the lawn mower shop or buying one from horizon. You are correct, the other carbs are 1/2" venturi carbs and are too big for the usual Ryobi 31. But the Wa 167 is a perfect carb for your engine. It is what I have on my Ryobi. There is another post, close to this one, where I put all the Walbro carb models that are the size you want. Copy the list. If you look around, you may find one of these models for $10 on a auction site? Enjoy, Jim |
Jim,
Thanks for the help, I'll do some searching to see what I come up with. Mike |
Is it possible to get the 167 without the primer ? That will be a pain to fit in through my firewall, I'm plan on using a flatplate mount and small stand-offs to get the correct engine length.
Mike |
Here is a list of Zama carbs that are 11 mm. Zama's run about the same as Walbro's if you get the same size. I don't know who did all the work of making this list but they did a great job. --Jim
C1U-K19, No choke, Primer, 2 needle, Echo, J/D 21C, 21S C1U-K20, A-C, No Choke, Primer, 2 needle, Echo, SRM-2501/2501S, SRM-2510 C1U-K21, No Choke, Primer, 2 needle, Echo, SRM-3000, J/D 30S C1U-K21A-B, No Choke, Primer, 2 Needle, Echo, SRM-3000, J/D 30S C1U-K22,A, No Choke, Primer, 2 Needle, Echo, J/D 38B, SRM3800 C1U-K23, No Choke, Primer, 2 Needle C1U-K23A-B, No Choke, Primer, 2 Needle, Lesco, LST24501/LHE2475 C1U-K34, No Choke, Primer, 2 Needle, Echo, SHR-2100 C1U-K34A, No Choke, Primer, 2 Needle, Echo, SHR-2100 C1Q-E3, No Choke, Primer, 2 Needle, Efco, Jet 300,400 C1Q-E4, No Choke, Primer, 2 Needle, Efco, Jet 300,400 C1Q-E6, No Choke, Primer, 2 Needle, Efco, EFCO 8742 C1Q-H17D, Choke, No Primer, 2 Needle, Homelite/JohnDeer, 200 Chain Saw C1Q-H35, Choke, No Primer, 2 Needle, Homelite/JohnDeer, 33-38cc Chain Saw C1Q-H42, Choke, No Primer, 2 Needle, Homelite/JohnDeer, 33-38cc Saw C1Q-H43, Choke, No Primer, 2 Needle, Homelite/JohnDeer, 33-38cc Saw Non Em C1Q-M27-C, Choke, No Primer, 2 Needle, McCulloch/Jenn Feng, 32cc Chain Saw C1Q-M27D, Choke, No Primer, 2 Needle, McCulloch/Jenn Feng, 32cc Chain Saw C1Q-M28-C, Choke, No Primer, 2 Needle, McCulloch/Jenn Feng, 35cc Chain Saw C1Q-M28D, Choke, No Primer, 2 Needle, McCulloch/Jenn Feng, 35cc Chain Saw C1Q-S44,A, No Choke, Primer, No Needles, Stihl, FC55 FS46 FS55 HL45 C1Q-S45, No Choke, Primer, No Needles, Stihl, FC85 FH75 FC75 HT75 HL75 S75/80/85 HT70/75 KW85 C1Q-S49,A, No Choke, Primer, No Needles, Stihl, HS45 C1Q-S49B, No Choke, Primer, No Needles, Stihl, HS45 C1Q-S50, No Choke, Primer, No Needles, Stihl, BG55/65/85 SH55/85 C1Q-S53,A, No Choke, Primer, No Needles, Stihl, FS46 FS55 HL45 C1Q-S54, No Choke, Primer, No Needles, Stihl, 4228 C1Q-S55, No Choke, Primer, No Needles, Stihl, BG55/65/85 SH55/85 C1Q-S56, No Choke, Primer, No Needles, Stihl, FH75 FC75 HT75 HL75 FS75/80/85 HT70/75 KW85 C1Q-S58, No Choke, Primer, No Needles, Stihl, FS55 C1Q-S60, No Choke, Primer, No Needles, Stihl, 25 CC ST / Brazil C1Q-S62, No Choke, Primer, No Needles, Stihl, 4140 CA Version C1Q-S63,A, No Choke, Primer, 2 Needles, Stihl, FS75/80/85 HT70/75 C1Q-S64, No Choke, Primer, 2 Needles, Stihl, BG45/46/55 SH55/85 C1Q-S66, No Choke, Primer, 2 Needles, Stihl, EMU ST FS45/46/55 C1Q-S67, No Choke, Primer, 2 Needles, Stihl, 4228 EMU HS45 C1Q-S68, No Choke, Primer, 2 Needles, Stihl, 4229 BG85 Blower C1Q-S68A, No Choke, Primer, 2 Needles, Stihl, 4229 BG85 Blower C1Q-S69A, No Choke, Primer, 2 Needles, Stihl, 4137 EMU Trimmer C1Q-S70, No Choke, Primer, 2 Needles, Stihl, HS45 Hedgetrimmer C1Q-S71, No Choke, Primer 2 Needles, Stihl, 4140 FS55 Trimmer C1Q-S74,A, No Choke, Primer, 2 Needles, Stihl, 4314 BT45 Drill C1Q-S79, No Choke, Primer, 2 Needles, Stihl, 4610 EMU Minni-Tiller C1Q-S95, No Choke, Primer, 2 Needles, Stihl, FS38 Stringtrimmer C1Q-SK8, No Choke, Primer, 2 Needles, Yanmar Brushcutter, Honda B.C./S.T., Shibaura M35D C1Q-SK9, No Choke, Primer, 2 Needles, Lesco B.C./S.T., Shibaura M35D C1Q-W14, Choke, No Primer, 2 Needles, Poulan/Weedeater, 36/42 LE CSI Non AV Saw C1Q-W14A, Choke, No Primer, 2 Needles, Poulan/Weedeater, 36/42 LE CSI Non AV Saw C1Q-W2A, No Choke, No Primer, 2 Needles, Poulan/Weedeater, Super 25 Chain Saw C1Q-W8, Choke, No Primer, 2 Needles, Poulan/Weedeater, Wood Shark Chain Saw, Patriot 1900 Saw C1Q-W9, Choke, No Primer, 2 Needles, Poulan/Weedeater, Sears 2.6 18" LS Saw, Poulan 2250 LE 18", Poulan Pro 221 16" LE CA, Poulan Pro 260 18" LE CA, Poulan Pro 2250 18" LE CA C1Q-W9A, Choke, No Primer, 2 Needles, Poulan/Weedeater, Sears 2.6 18" LS Saw, Poulan 2250 LE 18", Poulan Pro 221 16" LE CA, Poulan Pro 260 18" LE CA, Poulan Pro 2250 18" LE CA |
Mike
Try Scott Ellingson at www.scottellingson.com. He converts engines and on his web page he says he has Walbro carbs from 11mm to 15mm. His prices are great and he is great to work with. http://www.scottellingson.com/brillelli_003.htm Thanks |
Here is a list of all the 11mm Walbro carbs and what they come off.
KMM (Tim) HDA-113-1 11,11 ZENOAH HDA-131-1 11,11 TANAKA HDA-135-1 11,11 ZENOAH HDA-147-1 11,11 SOLO HDA-149-1 11,11 ZENOAH HDA-155-1 11,11 SOLO HDA-168-1 11,11 EMAK HDA-169-1 11,11 EMAK HDA-59-1 11,11 HOMELITE HDA-60-1 11,11 HOMELITE HDA-64-1 11,11 HOMELITE HDA-70-1 11,11 ZENOAH HDA-90-1 11,11 ZENOAH WA-137-1 11,11 ECHO WA-138-1 11,11 ECHO WA-144-1 11,11 TRAIL WA-150-1 11,11 TANAKA WA-154-1 11,11 TANAKA WA-162-1 11,11 ECHO WA-166-1 11,11 TANAKA WA-167-1 11,11 ZENOAH WA-173-1 11,11 ZENOAH WA-174-1 11,11 ZENOAH WA-175-1 11,11 ECHO WA-190-1 11,11 MIROHO WA-192-1 11,11 ZENOAH WA-193-1 11,11 ZENOAH WA-196-1 11,11 ECHO WA-197-1 11,11 ZENOAH WA-203-1 11,11 OLEO MAC WA-208-1 11,11 TANAKA WA-210-1 11,11 ALPINA WA-213-1 11,11 ZENOAH WA-222-1 11,11 ALPINA WA-55-1 11,11 ECHO WT-105-1 11,11 CURTIS DYNA WT-108-1 11,11 SOLO WT-130-1 11,11 McCULLOCH WT-131-1 11,11 ALPINA WT-139-1 11,11 TANAKA WT-144-1 11,11 TANAKA WT-145-1 11,11 TANAKA WT-146-1 11,11 TANAKA WT-214-1 11,11 ECHO WT-239-1 11,11 WEEDEATER WT-243-1 11,11 TANAKA WT-249-1 11,11 ZENOAH WT-250-1 11,11 TANAKA WT-252-1 11,11 TECUMSEH WT-258-1 11,11 McCULLOCH WT-261-1 11,11 ECHO WT-263-1 11,11 McCULLOCH WT-265-1 11,11 TANAKA WT-271-1 11,11 ECHO WT-289-1 11,11 WEEDEATER WT-297-1 11,11 ECHO WT-301-1 11,11 SHINDAIWA WT-323-1 11,11 STIHL WT-324-1 11,11 WEEDEATER WT-337-1 11,11 FOX WT-347-1 11,11 McCULLOCH WT-348-1 11,11 McCULLOCH WT-350-1 11,11 WEEDEATER WT-356-1 11,11 ECHO WT-358-1 11,11 ECHO WT-378-1 11,11 SHINDAIWA WT-382-1 11,11 SHINDAIWA WT-391-1 11,11 WEEDEATER WT-40-1 11,11 SHINDAIWA WT-404-1 11,11 TANAKA WT-407-1 11,11 TANAKA WT-410-1 11,11 ECHO WT-415-1 11,11 ECHO WT-42-1 11,11 SOLO WT-433-1 11,11 HOMELITE WT-437-1 11,11 McCULLOCH WT-438-1 11,11 McCULLOCH WT-462-1 11,11 STIHL WT-464-1 11,11 DYNAMIC WT-478-1 11,11 TANAKA WT-499-1 11,11 ZENOAH WT-504-1 11,11 ECHO WT-511-1 11,11 DYNAMIC WT-516-1 11,11 TANAKA WT-517-1 11,11 TANAKA WT-518-1 11,11 FRIGIDAIRE WT-522-1 11,11 FRIGIDAIRE WT-524-1 11,11 DYNAMIC WT-527-1 11,11 TANAKA WT-530-1 11,11 US ENGINE WT-534-1 11,11 ALPINA WT-551-1 11,11 TANAKA WT-552-1 11,11 SOLO WT-553-1 11,11 TANAKA WT-563-1 11,11 STIHL WT-568-1 11,11 ECHO WT-569-1 11,11 ZENOAH WT-572-1 11,11 SHINDAIWA WT-576-1 11,11 ZENOAH WT-72-1 11,11 HOMELITE WT-72-1 11,11 HOMELITE WT-74-1 11,11 ECHO WT-77-1 11,11 ECHO WT-86-1 11,11 ECHO WT-88-1 11,11 ECHO WT-94-1 11,11 EMAC WTA-13-1 11,11 TECUMSEH WTA-14-1 11,11 TECUMSEH WTA-15-1 11,11 TECUMSEH WTA-17-1 11,11 TECUMSEH WTA-2 11,11 TORO WTA-3-1 11,11 TECUMSEH WTA-4-1 11,11 TECUMSEH WTA-5-1 11,11 TECUMSEH WTA-6-1 11,11 ZENOAH WTA-7-1 11,11 RYOBI WTA-9-1 11,11 TECUMSEH WA-1 11,13 STIHL WA-106-1 11,13 ECHO WA-1-1 11,13 STIHL WA-112-1 11,13 ZENOAH WA-113-1 11,13 ZENOAH WA-115-1 11,13 SHINDAIWA WA-126-1 11,13 TANAKA WA-13-1 11,13 TANAKA WA-133-1 11,13 ECHO WA-14-1 11,13 SOLO WA-141-1 11,13 ECHO WA-142-1 11,13 ECHO WA-151-1 11,13 TANAKA WA-155-1 11,13 TANAKA WA-18-1 11,13 WEEDEATER WA-19-1 11,13 WEEDEATER WA-1-C 11,13 STIHL WA-200-1 11,13 PETCO WA-2-1 11,13 STIHL WA-23-1 11,13 CAMPBELL WA-24-1 11,13 CAMPBELL WA-25-1 11,13 ECHO WA-26-1 11,13 ECHO WA-27-1 11,13 JOBU WA-30-1 11,13 DESA WA-31-1 11,13 DESA WA-32-1 11,13 ECHO WA-33-1 11,13 ECHO WA-34-1 11,13 SOLO WA-36-1 11,13 DESA WA-39-1 11,13 ECHO WA-41-1 11,13 ROBIN WA-44-1 11,13 SHINDAIWA WA-53-1 11,13 ALPINA WA-54-1 11,13 ALPINA WA-58-1 11,13 TRAIL WA-60-1 11,13 SACHS DOLMAR WA-64-1 11,13 ZENOAH WA-65-1 11,13 TANAKA WA-71-1 11,13 EFCO WA-73-1 11,13 OLEO MAC WA-75-1 11,13 ECHO WA-76-1 11,13 ZENOAH WA-78-1 11,13 TRAIL WA-8-1 11,13 PIONEER WA-85-1 11,13 SACHS DOLMAR WA-86-1 11,13 STIHL WA9-1 11,13 ZENOAH WA-92-1 11,13 CURTIS-DINA WA-93-1 11,13 ECHO WA-96-1 11,13 ECHO WA-99-1 11,13 STIHL WT-15-1 11,13 STHIL WT-21-1 11,13 STIHL WT-29-1 11,13 STIHL WT-44-1 11,13 FRIGIDAIRE WT-570-1 11,13 JOHN DEERE WT-8-1 11,13 PARTNER WT-83-1 11,13 FRIGIDAIRE WT-9-1 11,13 SACHS DOLMAR WTA-12-1 11,13 TECUMSEH |
Thanks guys !
| All times are GMT -8. The time now is 01:03 PM. |
