26cc 4cycle what plane
Anyone no what plane would be good to try this engine on.
Ken |
RE: 26cc 4cycle what plane
Light , slow , scale type that doesn't go fast or need to. If you want speed then its not the engine for the job , but I liked the slower planes.
How heavy is the engine?
What size prop does it turn? How many RPM? Bill |
Captain, at 66 I like things slow too. Bill , when I get the engine I will see if I can give you some spec's.
Ken |
You might just be able to fly a Sig Rascal 110 with it. I have this same trimmer, in use as a trimmer, and a Rascal 110 with a Honda GX31. Although the plane is large it is VERY light for it's size and by the math (rpm and prop size) that others have found with the GX25 (25cc 4 stroke) I think it would fly the plane. If this one is close to the GX25 I think you will be OK.
Thanks, I will check it out.
Ken |
| All times are GMT -8. The time now is 04:38 PM. |
