Plane for Ryobi?
1 Attachment(s)
I just bought my first engine for conversion today at harbor freight for $50.00 ;) I need to know what you guys think about the Seagull Laser 200. I can get one really cheap at a shop that is closing. Here are some pics of the weedy & the specs of the plane.
Laser 200 120 ARF Specs Wing Span: 68.75 in (175cm) Overall Length: 63.4 in (161cm) Wing Area: 735.6 sq in (47.4 sq dm) Flying Weight: 10-11 lb (4.5-5kg) Engine Size: .90-1.20 2-stroke or 1.20-1.50 4-stroke Radio: 4 channel Servos: 6 Trim Scheme Colors: Ultracote Yellow CG (center of gravity): 1.5" (37mm) behind leading edge measured at wing tip Prop Size: 15x8 or 16x8 with 1.20 4-stroke Spinner Size: 3" Hardware Included: Yes Flaps: No Retracts: No Control Throw (Ailerons): Low Rate - 3/16" up/down or High Rate - 3/8" up/down Control Throw (Elevator): Low Rate - 3/8" up/down or High Rate - 7/8" up/down Control Throw (Rudder): Low Rate - 3/4" right/left or High Rate - 1-1/4" right/left Scale: 1/4 Approx. Assembly Time: 20-30 hours |
RE: Plane for Ryobi?
Being as the plane is designed for a glow engine and the Ryobi is rather long, you will have a very nose heavy plane unless you shorten the nose or take other measures to balance the plane.
Enjoy, Jim |
So as far as power & wing loading are concerned, other than weight, the Ryobi should fly it fine?
It will fly with gusto as far as a Sportsman's plane goes. You will love it for general pupose flying.
It is not going to be a 3D plane. The engine will make the plane too heavy for that. Enjoy, Jim |
That's perfect. I'm not interested in 3D.
Did you get the Laser 200 for your Ryobi? If you can build it to 11 lb with the Ryobi, your cubic wing loading CWL = 15.2 which is high. I put a Ryobi 30 cc engine in a .90 sized plane that was about 744 sq in in area and the CWL was 15.0 and it flew.
A CWL of 7 is a floater so at 15, if your engine is not running right, you will struggle to take off. On my first flight I made it into the air but because the engine was not run-in, it sank and I belly-flopped her in. Broke the fuselage in half. I glued her back together and popped a 20x8 APC trimmed to 19x8. She took off and flew well until flutter removed my left aileron. With the heavy wing loading, I could not keep her in the air. |
Lmao this thread is 13 years old! Thanks for the tips though ;)
I abandoned the project after it backfire and the flywheel went one direction and the propellar went the other. I do still have it but never messed with it any more. I bought a 78" Super Chipmunk to put it on and a few years ago I bought a DLE 30 to put on it but that has not been done either.
| All times are GMT -8. The time now is 06:26 AM. |
