Small Conversion Engines For This Twin?
I'm thinking 20cc+/- for this twin SkyMaster.
http://www.internet-rc.com/ces02abskymb.html I've been wanting to build this plane for YEARS, but I can't bring myself to buy 2 glow engines.[:'(] I'd be much happier with a couple little conversion engines on this plane. Any ideas on what motors to get for it? I was looking at the Brillelli 25GT Toro engines, but I think 2 of them will tear this plane apart. Something smaller. Thanks |
RE: Small Conversion Engines For This Twin?
A 13 lb. airframe is not likely to be strong enough to support two gas engines.
Bill |
ORIGINAL: BillS A 13 lb. airframe is not likely to be strong enough to support two gas engines. Bill I can build reinforcement into the firewalls and fuse sides if needed. A 120 4-stroke glow engine weighs just a bit over 2 pounds. Scotts 25cc Toro weighs only 3.5 pounds. I can't see why a 20 or 21cc engine wouldn't be a bit lighter than that. Maybe 3 pounds if I could find a nice, light engine. You saying an airframe with 87" of wing won't support an additional 2 pounds worth of engines? I could use little 8 or 10oz fuel tank. I'll bet the overall weight gain over 120 4-strokes would come out to about 1 or 1.5 pounds. That airplane can handle that much--no problem. Anyone know of any small gassers--not too heavy--that I could put on this plane? |
if you can find the little shindiawa I think 23cc or 21cc engines they are 2.5 lbs each with a muffler and my lightened flywheel I will post a pic. later. I am puting one of these on a 96 in monocoupe.
Darin |
I just looked at the pic. of the plane and I think you might have a clearance issue with a magneto flywheel and cowl.
Darin |
Your also going to have to find the appropriate size pusher prop for that rear engine.Both engines will be turning the same direction (C.C.W)when viewed from the front of each engine.Your probably going to have to use a CH type ignition system on these engines and do away with the magneto because like was mentioned already,I don't think your going to have the cowl clearance,unless you set back the firewalls a bit and use a much longer prop hub adapter;).They would have to be custom made no doubt.Any other way would have the cowls so chopped and modified,it would just end up looking dorky.;)
ORIGINAL: Turbobeaver Your also going to have to find the appropriate size pusher prop for that rear engine.Both engines will be turning the same direction (C.C.W)when viewed from the front of each engine.Your probably going to have to use a CH type ignition system on these engines and do away with the magneto because like was mentioned already,I don't think your going to have the cowl clearance,unless you set back the firewalls a bit and use a much longer prop hub adapter;).They would have to be custom made no doubt.Any other way would have the cowls so chopped and modified,it would just end up looking dorky.;) I know that you can make a Ryobi run backwards if you just put the hall sensor on the opposite side and flip it backwards. But, thats only because it's a reed induction through the backplate. I don't think you can reverse the operation of a piston ported engine--I could be wrong. I really don't see a need to run 1 engine reversed on this plane. With both engines running in the normal direction--torque will be canceled out. Thats the beauty of an inline twin. I'm checking into the threads that discuss gas/glow fuel combination--where the engine is run on a glow plug and no magneto or coil. Thats would be light, and no magneto to interfere with the cowls. I'd prefer C&H and run regular gas 40:1 mix--but I'll do a gas/glow hybrid if I have too. |
ORIGINAL: bn120 if you can find the little shindiawa I think 23cc or 21cc engines they are 2.5 lbs each with a muffler and my lightened flywheel I will post a pic. later. I am puting one of these on a 96 in monocoupe. Darin |
Possibly 2 Echo/Kioritz ,,,hmmmm they were either 16 or 18cc engines. Conversionists sometimes discard these because of the power to weight issues,,but they just might be the ticket for your plane. Converted to EI they should be light enough and I see that plane only calls for 2 .91 4 strokers.
Why not? However it is your money and your project. Bill |
ORIGINAL: Tauri Flyer Possibly 2 Echo/Kioritz ,,,hmmmm they were either 16 or 18cc engines. Conversionists sometimes discard these because of the power to weight issues,,but they just might be the ticket for your plane. Converted to EI they should be light enough and I see that plane only calls for 2 .91 4 strokers. Thats why I think an 18--21cc gas engine would be just about right. |
1 Attachment(s)
here you go
if you run (gas/glow hybrid) you can get these ready to fly at 2 lbs. no problem I would love to help you out on this project. If you need any custom work let me know. I think you are on the right track, dont give up on this.
Darin |
BN120:
Where'd did you find those engines? Are they the Shindiawa engines you talked about earlier? Weedeaters? Leaf Blowers? What brand of machine are they usually in--i.e. weedeater, poulan, yard machine I'm going to need a prop hub, and maybe some other machineing. So, I'd love some help, thanks. Of course, I'd pay you for the help and machined parts. Not looking for a free ride. I can't buy the plane untill I figure out the powerplant. Otherwise, I'll have a plane that will never fly--'cause I'm not using glow on it. Now, where do I find those little jewels? This is looking better and better all the time. |
ORIGINAL: BillS Why not? However it is your money and your project. Bill I've got some guys here willing to help me dig up the right motor. BN120 has offered to help with machineing. This can easily be done with motors that weigh under 3 pounds. I'm guilty as anyone for saying stupid stuff and makeing comments where I should just mind my own business. It's something I'm working on. Trying to only comment when I can help in a positive way--or I have had the plane/engine before and know what I'm talking about. It's a work in progress, but I'm aware of it and trying to get better about it. The Skymaster Twin has been a dream of mine since I started flying. Almost 8yrs ago. It's the same as a guy who builds a scale B-17 or a 30% Cessna 182. It might not be perfectly 100% scale, and it might be a little overweight, but It's my dream man. I'm in love with this plane. Quit trying to squash my dreams man. Your killin' me. ;) Back to these engines: I'm all over the internet looking at 18 and 21cc engines. I haven't found a Shanindiawa yet, but weedeater makes a 21cc engine |
the newer one is a c230 trimmer the older one is a couple ounces lighter and it is also 21 or 23cc b ut I dont know the model #
Two old style G23s with all the extra stuff cut off, using aftermarket ignition, would work..We flew a 110 lb, 16 foot wingspan DOX seaplane with 6 of these, using 14-10 Zinger props...
Tried 15-8s, not enough rpm to get the thrust needed to get off the water..Flew it at about 1/2 throttle once in the air.... |
http://www.shindaiwa.com/products/br...ters/c230.html
I just looked up the older one, is a t230 Darin |
ORIGINAL: RCIGN1 Two old style G23s with all the extra stuff cut off, using aftermarket ignition, would work |
I'm doing a search in this forum for this engine:
http://www.walmart.com/catalog/produ...Specifications I'm not having much luck locating a Shindaiwa engine locally. Any comments on the featherlite leaf blower from Poulan? 18cc Edit: Just been searching and reading up on the featherlite 18cc engine. Doesn't look to good. It could be made to run decent, if you wanted to do a bunch of machine work to it. I don't. It's not going to work. Most guys say the 21 and 25cc engines are as light as the featherlite. |
39 oz with muffler ready to go on the older ones or 41oz. with the newer ones the older ones put out a little more power and weighs less, had the older one on a h9 90 size funtana at 10 lbs it had slow unlimited verticle . This is on straight gas with the lightened flywheel and lightened muffler and the fat trimmed from motor. I could probably squeeze a couple more oz. that I can see. I checked again and I am not sure what the older one is I have a unconverted one at the hangar I will go see what the model # is. later today.
I think we can get you set up with a pair for under 5lbs. ready to go. will you have the clearance for a 16in. or 18in. prop what about magneto clearance.if you want to run magneto and dont have the clearance thats ok I can move it to the rear and will and 1.5 oz. Darin |
I can get those the same weight, they will be cheaper but have less power, but at 15 lbs with 2 I think you will have more than enough even at higher altitudes. but I hate the spring mufflers.
Darin |
does anyone know the weight on these poulan pro 25 cchttp://www.lawnstation.com/Line_Trimmers/Poulan/LSPL25SST.html
Rcpilet..Converted G23s...Right at 2 lbs, +or- an ounce or two...
Here's my two cents worth!!! Try the weadeater 18 or 21 CC converted to Gas/Glow Hybrid these will start on "either direction" so you don't have to purchase especial props, just invert the prop side and the starting rotation on the rear engine, these engines converted to Gasd/Glow Hybrid should weigh less than 2 pounds and would be a great substitue for a 60 or 90 size plane; on this forum some mentioned thar they were selling these engines for $ 35.00 I will try to locate the info from back dates also there was some one on e-bay selling these little gems, another great deal to try is this one www.duropower.com they have a 26 cc engine that is a Zenoha replica from china for $49.00; But best of all if this is your "DREAM PLANE" I'll plainly tell you "DON'T SIT THERE GO FOR IT BUDDY" there is nothing like building your dream come true.
same goes for my little fokker dr1 it was my dream plane and I only fly her once a year, other wise it is the only indor pet of the prop kind hanging from the ceiling in the living room.
AERONUT I called them to get a few to try and they dont even have them, they just put them on there to see if there was any interest, so everyone needs to call and tell them you need 10 thats what I did so call ;) maybe if enough of us call they will get them. Darin RCIGN1 is that ready to fly with ignition, battery and muffler? the little echo will work nice also |
Aeronut I dont think you want to run a engine clockwise unless you have a left hand thread;)
Darin |
Bn120..Nope, engine and ignition only..Doesn't take much battery, current draw is 150-200 MA at WOT..Haven't weighed a muffler, there are too many out there...
This is interesting, I always liked this Aircraft, the full scale version, except for the hot running problems with the rear engine. The size of this model aircraft suggests that the wing loading is going to be a big problem. If it was sized for two .45 glo engines and they don't give the wing area or the wing loading, I would email them and ask what these two specifications are. Knowing these two numbers will help a lot in evaluating the possibilities of the project. I would guess that at 13.5 pounds this airplane doesn't have the lowest wing loading to begin with.
John |
let me suggest something in a slightly different direction. I chose to use an SPE 26cc in my Gp GeeBee which weighs only 2.5oz heavier than an OS Surpass 120 4 stroke glow. The less glow in my life the better. What I would do in your case is to install a dummy prop in the rear free spinning on a shaft on ball bearings. Stuff all the RX, pack, servos etc. as far to the rear as they will go and then run that SPE 26cc in the front. It puts out 12 lbs thrust. Two OS 70 surpass 4 strokes (within reccomended range) weight 44.1 Oz, with the one 26cc gasser it will weigh 6 oz LESS than with the two glows. It should fly nicely on that. As soon as that first engine fires the rear prop will be spinning. Other engines are available such as the 40cc version of the SPE26 which puts out 18Lbs thrust and weighs .8 lb heavier than the 26cc. No doubt that would be a FAST plane with all sorts of nice short field takeoffs like it did in Vietnam. You could go with flaps and slow the landing speed down too. Think about it this way, two OS 70 surpass engines that fit their reccomendation weigh in at 44.1 Oz, the 40cc SPE weighs in at 51oz. That gives you about 1/2 Lb more weight than the two glow engines and that would be easily dealt with. I think you can have your cake and eat it too. And let's face it, for less money and less hassle.
Not a bad idea.
But, I WANT twin engines. I've only had 1 twin, and it lasted about 2 minutes--and then somebody turned on a TX in the pitts. SPLAT!! I talked to Scott, and he's got a couple real small gassers that he's been working on. He said they would weigh 2lbs if I run them as a hybrid on glow/gas with no magneto and a glow plug. Thats cool--nice and light--but I'm trying to get away from glow fuel. Like Subarubrat said, "The less glow the better." I think Scott said his small weedies would weigh about 2.5 pounds with electronic ignition. Don't quote me on that. Ralph mentioned his G23 engines, and I'm interested in those too. I think with 87" wingspan and 13--14 pound flying weight, this plane will NOT be overloaded. I think it's going to be just fine. I've got aerobatic planes that weigh 16+ pounds with 87" wingspan and 1250squares. They will hover with a G62, and fly very light. I'll bet this plane has at least 1100squares. At 14 pounds, it should be fine. It could very well have 1200 or 1300 squares. I intend to contact them this week and get some info about the wing area. I know that a couple 1.20 glow engines (remember, my altitude is pushing 5000') would be the lightest thing to do. But, thats no fun, and expensive to fly. Can you imagine the fuel bill to feed 2 x 1.20 glow engines? [:'(][:'(] Gotta be gas, or not at all. CMP just released a bARF Skymaster with 81" wing for around $225--$250. Thats cool for a couple 46-60 glow engines. But, it doesn't look like it has functional rudders. I'd rather build a little bit bigger kit myself, and customize it to my taste. Probably cost me $500 for the airframe, but I still would rather build it than buy a smaller ARF. |
The Hybrid Gas /Glow uses 1 part glow fuel and 2 parts 91 octane gasoline with a glow plug and no ignition parts, that's why it's called a hybrid
Pretty sure buying CH ignition is more expensive than removing all mag & ignition parts and put glow plug in.
Last time I looked ign, sensor, & sparkplug weighs more than .... nothing, no sensor, glowplug but you have to add a quart of glow to a half gallon can of gas lighter is better, stripped is lighter |
@*$&@! %$*#(%&ing %$@@#$ it, I think I just talked myself into my next project. Ever since I saw Bat21 I always wanted to build a skymaster, and that 40cc on that thing makes me grin.
A pair of my BCMA-SPE26 engines would be a really sweet combo for this plane. They weigh only 38 ounces each with the ignition module and have the power equal to my Zenoah G26. They are really close in physical size to a Saito 125 but they will have more torque! Auto Advance Electronic ignition is included along with engine mount standoffs and for $500.00 for the pair shipped, you will not find a better deal. JStanton is working on a review of this engine on a CMP Super Chipmunk.
www.bcmaengines.com |
Speaking of such, I haven't recieved my SPE26 yet, is it on the way? Can't wait to fire it up in that GeeBee. Thanks much.
-Scott S in VA |
| All times are GMT -8. The time now is 04:18 AM. |
