RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   STIHL 27CC SPECIFICATIONS (https://www.rcuniverse.com/forum/engine-conversions-92/4454611-stihl-27cc-specifications.html)
box car 07-02-2006 10:14 AM
This engine looks to be a little power house stock. Cost $129.00 in a G-45 trimmer. Prop range 16-8 to 18- 8.
No load engine RPM is 9500. Weight with mag, stock muffler, prop hub, zinger 16-8 prop and DuBro 3" spinner is 67 ounces about 4 lbs. This weight can be cut way down. This info was from a Stihl conversion web.( Hints and Tips for RC Modelling ) Pan down to Stihl conversions, I got mine yesterday, need to get to work on it.
tim220225 07-02-2006 10:20 AM
RE: STIHL 27CC SPECIFICATIONS
The link does not work.
box car 07-02-2006 01:51 PM
Tim I put in a new link, I should have checked it to make sure it worked. The new one I put in will get you there.
tim220225 07-02-2006 07:00 PM
Ken,
I can't figure it out. Now there is no link. I have a couple of Stihls on the way that are used and need I any info I can get.
Tim
box car 07-02-2006 07:24 PM
Tim, just type in( Hints and Tips for RC modelling ) in your search bar and it will bring it up as a web then just click on it and it will take you there. I have a 23cc Stihl with EI turns a 16-8 at 8400 RPM. I don't think you even have to do any porting on them.
davewallace 07-02-2006 07:43 PM
Tim,
Here is the link. http://www.geocities.com/CapeCanaver...tihl/stihl.htm
Dave
box car 07-02-2006 08:40 PM
Way to go Dave, That was the first link i put up and did'nt work, might have missed something in the link. Thanks for helping Tim out
tim220225 07-02-2006 10:21 PM
Thanks Dave. That looks like what I am expecting soon. Have to weigh it against the Toros I have done.
icando3d2 01-09-2007 12:05 AM
ok so i am almost done converting one of these this is my second conversion i retained the stock ignition on this the only cutting i had to do was to shorten the front crank a bit so my adapter would go on easily,
captinjohn 01-09-2007 10:43 AM
icando3d2: Have you ran the Sthil 27cc engine yet? What kind of RPM & what prop are you using? Thanks Capt,n
