RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   What cc is Weedeater 1500 engine (https://www.rcuniverse.com/forum/engine-conversions-92/4505295-what-cc-weedeater-1500-engine.html)
RevGQ 07-15-2006 05:43 PM
I love tickering in this hobby and was saving an old Weedeater 1500 to convert. I stripped it from its trimmer housing, but am not able to identify the size of the engine. Since most of the numbers start with "28", I am assuming that it is a 28cc motor. Any help with identifying the size and thrust output would be greatly appreciated. Also, can anyone recommend conversion parts for this motor. Thanks again.
davewallace 07-15-2006 08:12 PM
RE: What cc is Weedeater 1500 engine
Hi rev,
The 1500 is most likely a 18cc engine. It will work as a gas/glow conversion. I think that it is a bit over weight with mag ignition. It isn't good enough to spend money for electronic ignition. Hrer is a link for the FL-1500 below.
Dave
http://www.weedeater.com/products/bl...rod_FL1500.asp
RevGQ 07-16-2006 05:24 AM
1 Attachment(s)
Thanks, but I don't think that is the motor. The motor I have came from a trimmer. I did do a parts check on the one you suggest and there were no matches. I do believe it is a 28 cc motor based on the numbered parts. Thanks again.
RevGQ 07-16-2006 05:28 AM
1 Attachment(s)
more Pics of engine:
davewallace 07-16-2006 09:16 AM
Hi Rev,
Without a picture, I was going on what you said about it being a 1500. It is a Weedeater XR series engine. I had a small one, many years ago. I replaced it later with a XT-90 of 30cc. Both series have reed valves. The XR on the bottom and the XT in the rear. The flywheel threads are most likey 5/16x24. You will have to enlarge the ports and trim much metal from the case to have usable engine. I would recomend going to a small engine repair shop and picking a good used Homelite or Ryobi for $5 or free. A picture is worh ten thousand words. good luck.
Dave
RevGQ 07-16-2006 12:47 PM
What a guy Dave: thanks for the heads up. I keep forgetting that I have this digital camera. It is nice to have the right tool for the job at hand, LOL :)
