RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   Long shaft solution? (https://www.rcuniverse.com/forum/engine-conversions-92/4507681-long-shaft-solution.html)
davewallace 07-16-2006 11:59 AM
1 Attachment(s)
Hello everyone,
I came across this picture on ebay and wondered about the best way to do this. It would be a great engine for a P39 or P63 King Cobra. Has anyone seen a solution like this before?
Dave
Antique 07-16-2006 01:50 PM
RE: Long shaft solution?
Me..I made something similar about 12 years ago for a P39 racer using a 150 four stroke..Mine was made from solid aluminum, not bolted together...still have the piece around her somethere...Way too heavy, even though it was milled out on the sides and bottom...:D
There's another way..
I made a 10" long extension for a 3W 70 twin to be used in a Nemesis F1 scale racer..
Threaded an aluminum tube to the front of the crankcase, made a long shaft that screwed onto the crank, put a bearing in the end of the tube..Worked fine, the engine wasn't quite strong enough to win....
davewallace 07-16-2006 05:29 PM
Ralph,
The tube idea sounds like a good solution. I still think that the fusalage would nedd to be nice and stiff for support. :eek:
mgnostic 07-17-2006 06:08 PM
Looks like it could be good for any skinny pointy nosed airplane. You know, a flying version of Lindsey Lohan. I hadn't yet run across an engine with a shaft that long before. What is it out of?
davewallace 07-17-2006 09:11 PM
Matt,
I think that it was custom made for a P39 Aircobra. Not sure how well it worked. Thought that it might cause activity int he forum. Things have been slow latley.
Dave
buck1856 07-17-2006 10:50 PM
Ill have to keep my cheepo digital camera with me.Theres a guy at my field that showed up last month with a warbird,not sure what it was because it was only the fuse but he had a quadra 35 in the cockpit and a long hub that went to a bearing on the firewall.No support in the middle.Had one of those little squared like mufflers from jtec with the hose running out the bottom.
