RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   4 stroke 29cc Trobilt (https://www.rcuniverse.com/forum/engine-conversions-92/4549646-4-stroke-29cc-trobilt.html)
motorhd 07-26-2006 10:57 PM
I saw a Ryobi 4 stroke 29cc trimmer at Lowes today. Looks different than the 26 cc. Maybe smaller? Anyone have any experience with these? Looks like a good conversion prospect.
Motorhd
davewallace 07-27-2006 08:42 AM
RE: 29cc Ryobi
Motorhead,
Did you notice if the engine design was easier to mount? The European 4Cycles have a dual shaft and a pull start in back. When removed it makes a nice motor mount like Toro, Echo etc. How did it cost?
Dave
motorhd 07-27-2006 11:23 AM
RE: 29cc Ryobi
They are Troybilt mod# TB525 and TB575. The case on one of them is more like other engines instead of cut off at a 45 degree angle for the oil pan and the pan is more like a backplate. Should be an easier mount. Current price is $160. and $190. Somebody needs to take a digital camera to Lowes.
hollbrow 07-28-2006 07:14 AM
RE: 29cc Ryobi
I have not seen these yet- I may be wrong, but I think that what you are seeing may be a third rendition of the 'Ryobi' four stroke-The first ones years ago were dogs but they keep getting better- I think Zenoah actually had a hand in some of the design for the 2nd version. I am pretty sure MTD owns the rights to them now-
I know they own Troy-Bilt. This engine could appear in a plethora of equipment.
Someone get one and check it out- or as above- go snap us a pic of it.
hollbrow 07-28-2006 07:47 AM
RE: 29cc Ryobi
I called a buddy of mine at a lawn and garden shop- he gave me the skinny on the 29cc-
says it is a half crank engine- says it reminds him of a cross between a ryobi 31cc two stroke and a honda GX31.
It has a backplate like the 31cc- so it would be easy to mount on a firewall- but the oil plug is in the backplate- so there would have to be a cutout or spacer for it. It has a cam/valve assembly similar to the honda- but unlike the honda, has a removable cylinder. The the pull start is integrated into the trimmer cover and the PTO end is similar- if not identical to a long shaft Ryobi with a clutch.
He couldn't comment on the power of it.
This may be worth looking into.
davewallace 07-28-2006 05:03 PM
RE: 4 stroke 29cc Trobilt
I went to Lowes today in San Antonio and both of the Troy-Built 4C trimmers were the old style oil sump. They were 29cc though. I guess there must be different models available.
Dave
