RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   ENGINE ROTATION (https://www.rcuniverse.com/forum/engine-conversions-92/5379576-engine-rotation.html)
captinjohn 02-06-2007 02:08 PM
ENGINE ROTATION
I have a question. Will a piston ported engine like a small Echo run with the same power in both directions? I know the ignition should be about 28* degrees before TDC at full throttle. Thanks Capt,n
xrae 02-06-2007 03:27 PM
RE: ENGINE ROTATION
I would think it would. The direction the piston/rod/crank is moving shouldn't matter if the timing is set right. Just my 2c
av8tor1977 02-06-2007 07:29 PM
RE: ENGINE ROTATION
Yep.
AV8TOR
tkg 02-06-2007 08:07 PM
RE: ENGINE ROTATION
Most piston ports do equally well running backwards. It won't hurt anything so give it a go and see.
We do this a lot for twin engined models so the plane behaves better.
captinjohn 02-06-2007 08:55 PM
RE: ENGINE ROTATION
tkg: Is it hard to find props for a 24cc gas engine that could be run clockwise? Capt,n
tkg 02-07-2007 01:02 AM
RE: ENGINE ROTATION
The trick is to use a Pusher prop on a reverse rotation tractor engine.
