RE: Volfy...pics of slits
Volfy: Are you still running the glow Ryobi engines? What is the best fuel mix? Is 0-5% nitro working good. I bet you have to be carefull of kickback. Back bounce starting may work? best regards Capt,n
RE: Ryobi 31cc glow conversion
I have 2 new wt 499s, retail is $48.18..
Boy, I completely forgot about this thread. Sorry.
I ended up selling the one in the picture above here on RCU. I still have two other Ryobi 31cc waiting for conversion - one brand new twin-ring, one old used single-ring. Too many conversion engines waiting their turn. When I get around to do a PT-19 or a Ryan STA or some other long narrow cowl airplane, I'll call up one of the Ryobi 31cc's for sure. As for fuel, 5% castor seems to be plenty. I'm sure syn blend would work too, but I would up it to maybe 7% instead. These low CR weedies likes a bit of nitro. It runs great on 15% nitro, but it looses quite a bit of power with less than 3%. I started with 0% and spiked it up to 5% bit by bit - all ran find, but transition definitely sweenten up noticeably around 3%. If I don't need to wring it out, that's what I'd run. I used a cheapo Tower glow plug and it worked great. I'm sure an OS "F" or Fox Miracle plug would work even better. Kick back was never a problem for me, again because of the low CR. If I really had some time, I would get rid of the cyl gasket and RTV it to raise CR, then trim the intake port a little to compensate. I'm sure it will pick up a few 100rpms and run better on low nitro. |
ORIGINAL: RCIGN1 I have 2 new wt 499s, retail is $48.18.. |
Volfy: I have some Byrons syn/castor fuel. It Is 10% nitro and 16% oil. I am not a math wiz...so about how much strait alky do I have to mix in to get close to that 3-5% nitro you use. Seems like 1 gal Byrons to 1 gal strait alky would give 5% nitro and 8% oil. But things are not always what it appears. Thanks for the interesting advice you have already posted. Regards Capt,n
RCIGN1 Have you ever ran a G38 with the WT499 carb using glow only? I would be very interested what rpm you got. Also what nitro content was the fuel? Thanks Capt,n
ORIGINAL: captinjohn Volfy: I have some Byrons syn/castor fuel. It Is 10% nitro and 16% oil. I am not a math wiz...so about how much strait alky do I have to mix in to get close to that 3-5% nitro you use. Seems like 1 gal Byrons to 1 gal strait alky would give 5% nitro and 8% oil. But things are not always what it appears. Thanks for the interesting advice you have already posted. Regards Capt,n Still, I wouldn't worry too much about the exact %. Just cut it 50/50 with methanol. You might end up with something like 4% nitro and 7% oil, but I doubt the Ryobi can tell the difference. You can spike it with more nitro after you've run the engine a bit and decide to try more. In case your Ryobi is brand spanking new, I would run it with the Byron fuel as is for a few tanks before cutting it down. |
Volfy,
If you don't mind telling me, where do you get your methanol here in Houston? Thanks, Will Varnado |
Good idea, Captin...Never tried a G38 set up that way, maybe when I get my WT499s I'll screw a glow plug in one and see what happens, should be interesting....[8D]
ORIGINAL: wvarn1957 Volfy, If you don't mind telling me, where do you get your methanol here in Houston? Thanks, Will Varnado |
MY G38 has the steel 6 hole hub...heavy flywheel and the coil itself is big and heavy. It runs nice...just to heavy for my Midwest G202. With all that dead weight gone and some extra HP , the G38 may work! Let me/us know when you run yours on Glow! Thanks Capt,n
As far as fuel delivery goes, WT-499 definitely had enough needle adjustment to keep up with the Ryobi 31cc, and probably a 38cc too. However, WT-499 has an 11.11mm venturi, which may be a bit on the small side for a 38cc glow engine. My guess is that it will work just fine for the G-38 and will have excellent throttle response, but WOT power might not be as great as with a slightly larger venturi carb.
RCIGN1: Are you getting close to running that G38 engine on Glow only? Forgive me for getting impatient !!!! Capt,n
The two carbs I had ordered got sold before testing, I ordered two more yesterday, they will be here by Tuesday...[8D]
Hello, Can you supply me a web site to frank bowman? My engine is torn down and I would like to install a new ring. Thanks
RCIGN1: How long has the WT-499 carb been in production? Can a person find one on a dead piece of power equipment? Thanks Capt,n
oldtimer2, The e-mail address for Frank Bowman is [email protected]
Railridr, Thanks for your responce, I sent an e-mail to his site requesting info. I appreciate your help.
Railridr, I received an answer from Frank with a piston ring list and another telling me how and what to order for ny engine. I will get the oder off in tomorrows mail. Thanks again George
I have a question I noticed that the pictures of airplane or airboats the motors have no expansion chamber style exhuast on them just wondering thanks
Volfy: Have you tried the gas/glow mix yet in your Ryobi? thanks Capt,n
ORIGINAL: captinjohn Volfy: Have you tried the gas/glow mix yet in your Ryobi? thanks Capt,n |
It is my understanding that the "slits" in the cylinder wall is to allow "OLD" guys like me to start the RYOBI in its intended original use, that being a weed whip. It is also believed that it may allow additional oxygen into the engine to reduce polution. I have several of the slotted blocks, and thought about plugging the slits, or set them for running, but to date I have enough blocks without slots to keep me busy for awhile. If I decide to run one, I will post the reasults on this site. FLATHEAD 4
My brother is running one of the Ryobis with the slits in the cylinder. It has a stock carb "massaged" slightly larger, and a free flowing muffler. No other mods. It turns an APC 18 x 6 at 7600 rpms consistently. I was rather surprised at how well it runs.
AV8TOR |
| All times are GMT -8. The time now is 06:14 PM. |
