RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   Rotary carb question (https://www.rcuniverse.com/forum/engine-conversions-92/6207081-rotary-carb-question.html)
flyrc100 08-07-2007 09:37 AM
I've got a little gas engine that runs great with the stock, although kinda small, rotary carb. The carb has a heck of a throttle spring in it, probably more than a servo could handle. There is a housing with two screws below the throttle arm, can that all be taken off to remove the spring without the whole carb flying to pieces?
Ralphbf 08-07-2007 11:13 AM
RE: Rotary carb question
Usually you can simply slip the spring off the throttle lever.
Leaveing the spring on the throttle shaft.
flyrc100 08-07-2007 12:24 PM
Thanks Ralph, but this spring can't be accessed unless you start taking something apart!
tstotts 08-07-2007 05:39 PM
Had a simliar experiance with a rotary carb and took it apart to remove the spring. The cylinder operates by moving the barrel up and down while rotating to control the gas flow on a stationary needle valve. The whole ordeal turned into a disaster. Now looking for a way of replacing the carb with a different type of carb. You might consider getting a hi torque servo instead.
captinjohn 08-07-2007 09:49 PM
It should not be that hard figure a way to solve the problem with the spring. Set down and take some time finding the solution. I will check into it more. Capt,n[:-]
flyrc100 08-07-2007 10:38 PM
I wish I had saved some of those rotary carbs, I tossed a bunch away, I could use a cadaver right now!
motorhd 08-07-2007 11:30 PM
Try taking the barrel out and then lift the hook on the end of the spring, up out of its slot. Let the spring relax and then cut a slot to in the plastic ridge to match the original shape but in the new relaxed position.you might want to make the location so it just goes to a closed position. This has worked well for me on several rotory carbs.
Motorhd
flyrc100 08-08-2007 08:40 AM
I actually found a rotary carb laying around today, from my son's scooter (sorry son). I removed the two screws and pulled the lower part out, you can pull the spring out of its slot with a small screwdriver or knife blade. Instead of trying to cut a new hole for the spring, I'm thinking just cut the tang off with a dremel tool.
tstotts 08-08-2007 10:13 AM
That sounds like a simple and logical way to go. I disposed of that spring long ago. Any ideas where a guy might find a replacement for it?
